Clear out. Last few bits
Loads of surplus bits and bobs from my recent project acquisition. Now some of the stuff I'm not 100% what fitment it is so feel free to correct me. Also if My pricing is off do feel to make me an offer. All are +postage or collect from just outside Glasgow.
2.0 zetec silvertop. This is an unknown as I've never heard it run. It's been stored with fresh oil In and it turns over nicely. I was going to try and compression test it  but I don't have the right adapter. The cam cover has been left off so there is a bit of surface rust on the lobes but should clean up. Also comes with HT lead set. Alternator. Starter and a set of westfield zetec engine mounts. (Apart from the bit that bolts to the chassis on nearside as it's welded in on mine). One injector plug is damaged. Selling really as spares or repair but may well be a good runner.
£SOLD
mt75 gearbox. Again I can't give an accurate indication of condition. It turns over smoothly In all gears and selects fine. Comes with a new clutch fork
£PROV SOLD
Sachs clutch kit (believe it's for this engine combo but I'm not certain so do your research) with new release bearing aswell.
PROV SOLD
mt75 to sierra diff propshaft. Brand new never used. Comes with new bolts.
£PROV SOLD
If anyone wants the full eng/Box/clutch/prop combo then give me a message id be happy to strap it all to a pallet.
Westfield exhaust can. 5"diameter 2" inlet. Complete with heat shield.
SOLD
set of avo shocks. Few years old but never used on the road. 12" fronts with 300lb springs. 14" rears with 180lb springs. SOLD
Front uprights. Believe these are cortina? I was told they have been reamed to fit the westfield upper and lower balljoints (and they do fit) bit of surface rust on spindles.
Also have a set of 245mm vented discs. Steel hubs (will need new bearings). And a set of 4 pot AP Lockheed calipers believed to be Capri princess?
No idea on price for these. £SOLD
Full set of new front standard wish bones. Complete with new ball joints upper and lower and bushes fitted. Brand new but have had a dodgy paint job so will need a repaint in my opinion.
£SOLD
Radiator and fan. No idea what it's off or for but it does tie up to the mounts on the chassis so must have been standard fit. PROV SOLD
Cycle wing stays. These for cortina? Please check they'll fit. SOLD
Spare wheel bracket?
£make me an offer
Few more bits to follow I suspect.
Steve.
Will pm about cycle wing brackets :yes:
Hi Steve. How much for the fuel pump. Pm me thanks jon
Just to add regarding the engine and the box. They've been sat in storage since around 2001 as I've found some receipts for some of the bits. So you could estimate 9 years use max. It didn't really take much effort to turn over.
Not a glowing report of health I know but thought I'd mention it!
If you fancy splitting the shocks, I'd be interested in the rears, Steve
I will have the radiator if you would post it please
@Kit Car Electronics Mike someone private messaged me before your post about the shocks and they've taken the full set sorry.
@1960dave Not a problem to post, will be about £10 p and p tho if thats any use to you?
Cycle wing brackets now sold.
sdh2903 Thats great send me payment details please
you have a pm!
RAD prov sold
I forgot to add, Im open to a bit of horse trading, need a few bits. ZK fuel tank, latest front wing brackets for westfield alloy uprights, Fuel tank IVA bar, LSD, AP racing upgrade master cylinder
I’ll have wing brackets just bent mine
Sorry already sold
Hi,
you have a pm
Engine. Uprights and brakes now sold.
Gearbox. Clutch and prop now PROV sold.
Any offers on the exhaust or front bones before eBay beckons?
I also have a brand new (but 15 years old) standard westfield tandem master cylinder available as well if anyone's interested.
Price drops before eBay
the wishbones now £SOLD
Exhaust now SOLD.
Also have a steering rack. Looks to be escort. Has clamps and bushes. Seems to be smooth enough. Just over 2 turns lock to lock (although lock stops may be fitted?)
Also a weird looking fuel tank. If it's of any use to anyone before I skip it then cover post and it's yours.
