I've got hold of the diagram for the holes if I were drilling through the scuttle to mount the heater and wiper motor, and Im just wondering if this is supposed to be central in the scuttle?
Seen a few builds where to me it looks like it's central, using the wiper holes as a reference, which on mine I've got to drill out.  If using the measurements from the diagram the heater is going to interfere with the top of the mouldings.
I'm going to use the Big Head m6 flush mountings and a patch of fibreglass for extra reinforcement, but just wanted to make sure I'm not making a dangler-up thinking this is supposed the be dead in the middle?
Mine looked like this . You can see the cutouts to go round the panel grommets in relation to being central.
5aad0a40a24db_130Scuttlefibreglassstuds.thumb.jpg.0fdb926e1b42224308f3adf05ab843a0.jpg
I used template as guide and worked out from centre line I drew on the scuttle (on tape obviously).
As ever treat template as guide and double check against "real world" before drilling, bonding or whatever.
