BugMan Posted October 21, 2017 Share Posted October 21, 2017 Just a quick question for all the builders out there, did anybody bother with the access hole for the gearbox oil access hole? Was spotted by my local club the other weekend when they came around for a look at progress that I have "err missed it" , and I have since asked the factory to have a look at one of there cars, and it appears they are not currently putting an access hole in at all? i had it in my mind to fit a 50 mm blind grommet but, if its not needed might not bother? Quote Link to comment Share on other sites More sharing options...
Alan Cutler (Adge) - Dorset AO Posted October 22, 2017 Share Posted October 22, 2017 I haven't cut an access hole, on the basis it could be done later if needed. Whilst it could be "interesting" some access is available from above and below. Another plus for making the tunnel top panels removeable. All down to personal choice. Quote Link to comment Share on other sites More sharing options...
Steve (sdh2903) Posted October 22, 2017 Share Posted October 22, 2017 It would make things easier having the hole but I managed to fill mine ok from below with a clear tube on the end of the bottle without too much drama. It's not a regular service item at 30000 mile intervals, granted it will probably get done much more frequently in these cars. Just as a side note if your doing a fluid fill/change make sure you do the fluid in the gear lever turret. Can make a big difference. 1 Quote Link to comment Share on other sites More sharing options...
BugMan Posted October 22, 2017 Author Share Posted October 22, 2017 Thanks team, think I will park the idea for now, planing to make all the top tunnel plates removable, following your example AdgeC Quote Link to comment Share on other sites More sharing options...
