Recommended me a rear view mirror
I'm after a new rear view mirror as my current one is a small 4" one from halfords And makes thing look small ,it's got a suction pad to stick it to the screen but it keeps falling off
I like the look of the 14" longacre ones but they are seem to be cage mounted which is no good for Me I also need to keep the window frame free for the half hood
So any ideas would be helpful
Have a look on the Westfield site...they have one not cheap but does the job...
That's you tried running with side mirrors only? I've got some decent convex lifeline ones and never even think about having a central mirror...
7 minutes ago, sdh2903 said:
This is the one Westfield supply but for less than half the price. It's a genuine lucas item and is quite large. I had a cheapo one but wouldn't stay attached for more than a day. This ones solid.
http://www.ebay.co.uk/sch/i.html?_odkw=322481315303&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.X.TRS0&_nkw=322514371731&_sacat=0
Just need to ensure you have strong glue as the sticky pad doesn't last long...
1 hour ago, RussH said:
That's you tried running with side mirrors only? I've got some decent convex lifeline ones and never even think about having a central mirror... @RussH I did try running with the standard side mirrors but found the view limited are your convex ones a direct replacement?
Thanks for that @Murraymint I'll have a look at that one
1 hour ago, Sparkymart said:
Mine bolt onto the cage, but other types are available :)
If you run a care the longacre ones are brilliant.
That's my problem no cage..
I'm OK with just the wing mirrors. My JKs (and I guess some others) leave a such a narrow slot to look through.
I've got a plan... I've got a phone holder with a Very compact adjustable clamp to hold phone , it's never dropped off the screen and even when you release the suction it's a struggle to get it off the screen
So a 14" longacre remove the mounting arms and just clamp it in place with the phone holder....
