Blyton Weekend Sprint Open
John Williams (Panda) - Joint Manchester AO
I've sorted the track day, booked my space at the meal, is there anything else I need to fill in?
Not unless you're taking up sprinting :d
Don't be putting that idea in my head!................'Crow Property Services Racing' does have a certain ring to it
Please can you confirm the track layout for both days. is it the same circuit layout as used in previous years or is one day different to the other?
Are the speed series boys that are booked on the trackday going to try and keep ON the track instead of spinning off ever 5 minutes?
John
There will be the normal sprint track and on the other day a different one !
25 minutes ago, terry everall said:
John
Ok thanks. I couldn't find anything in the regs that stated which circuit is being used
John
John, I cannot for the life of me work out how to send you a pm! Just wanted to say that I should be available to help at the trackday and the sprints at Blyton.
Stephen.
Stephen  If you move your mouse over their picture a screen will pop up and bottom right is a message icon.
or is it bottom left?
Not your bottom, Terry!
John, you have a pm., I think!
Believe the other track is the eastern circuit
Yes, I have now spotted that but the descriptions and lengths are quoted as identical hence confusion since I did hear 2 different circuits were being used
Am I right in thinking that the track day on Friday will be using both as well, one in the morning and the other in the after noon
