49 minutes ago, bunje said:
when its says low pressure how low is low enough 4.5 psi or does it need to be more than that.
https://www.merlinmotorsport.co.uk/p/facet-solid-state-electric-fuel-pump-only-1-5-4-0-psi-fac-ss500
would somethign like that do what i need
The pressure is not an issue but the flow rate is! The LP pump needs to supply sufficient quantity of fuel to maintain the level in the swirl pot. The pump listed may allow the swirl pot to be emptied during hard use as it is suggested it is ok up to 110hp and your engine is rated well above that Ben. In fact you should consider the implications of turning the boost up next year before you decide on a pump!!
Right I see thanks for the heads up martyn. Maybe a bit more research required
Sorry for the slight thread hijack. I'll continue asking my questions in my build thread
I guess the question is what is the flow rate required 20 gallons an hour is 90 Lt, so that would mean using 1.5 lt a minute which I would have thought is going some what should we be looking for.
That's the one I'm getting as part of the winter/spring upgrades :yes:
I've just ordered one of those pumps now too :)
What if anything are you all doing about the wiring?
Putting both pumps on the original pump wires or running new wires for the second pump?
Edit: I guess not much of an issue.
All Facet® low pressure fuel pumps 12v or 24v require an 5 Amps source to perform correctly. The DC average is 1.4 amps.
that was going to be my next question jared. i was wondering because my pump primes for 3 seconds then runs when the engine is cranking do i ned to wire the feed pump to the same system or does it need to be different
I just extended my fuel pump wires and have both on the same circuit
It can be the same Lewis, you're then utilising the same wiring to the pump relay. Then LP pump will operate just as the main one does as when the ECU turns off the main one the LP one will go off too.
if thats the case when i first fill the swirl pot will i need to cycle the fuel pump a couple of times
The pot should be full or near as dammit on start up anyway.
If plumbed correctly the pot should be full in operation spilling excess fuel out of the top back to the tank. When you stop the engine the pot should be full for the next start. Obviously if you'd left the car through the summer without running it some fuel might evaporate but not all of it.
best get ordering some more parts then.
