Josh Lawson Posted March 7, 2017 Share Posted March 7, 2017 I am currently experiencing fuel starvation going around high speed corners. Can anyone recommend a garage who can look at my car and offer a solution? I am doing a track day in June, so have a few months to get this sorted. Many thanks, Josh North London (Barnet) Quote Link to comment Share on other sites More sharing options...
Kingster Posted March 7, 2017 Share Posted March 7, 2017 Usual solution is to fit a swirl pot and low pressure pump to feed it. I know it doesn't point you to a garage but might help explain what you need Quote Link to comment Share on other sites More sharing options...
Josh Lawson Posted March 7, 2017 Author Share Posted March 7, 2017 Thank you Chris. Is the swirl pot heavy? I am concerned about adding unnecessary weight Quote Link to comment Share on other sites More sharing options...
Kingster Posted March 7, 2017 Share Posted March 7, 2017 Usually made from aluminium and holds around 1 litre of fuel so not too bad. Quote Link to comment Share on other sites More sharing options...
Kingster Posted March 7, 2017 Share Posted March 7, 2017 And if weight is an issue just use 2 litres less fuel. The starvation problem will be resolved so you won't need a high "minimum" amount that you do without one. 1 Quote Link to comment Share on other sites More sharing options...
B.RAD Posted March 7, 2017 Share Posted March 7, 2017 Assuming you have a standard fuel injection tank? These are well known to suffer from starvation, not really any quick solutions I'm afraid. As Chris says, swirl pot is the most effective and "easiest" solution. Alternatives are replace the fuel tank with a proper baffled tank with sump or fill the tank with foam fuel blocks (not recommended - can break down over time). Quote Link to comment Share on other sites More sharing options...
DE04* Posted March 8, 2017 Share Posted March 8, 2017 My fuel tank has a sump which is always full,that feeds the pump and never had a problem Quote Link to comment Share on other sites More sharing options...
corsechris Posted March 8, 2017 Share Posted March 8, 2017 Do we know this engine is injected? Could be carbs, in which case, might be float levels, although could still benefit from a swirl pot even then. Quote Link to comment Share on other sites More sharing options...
stephenh Posted March 8, 2017 Share Posted March 8, 2017 K series is likely to be injected, I would have thought? The sump in the factory standard injection fuel tank is fine for road and relatively gentle trackday use, but with high power/fuel consumption and sticky tyres driven hard they will still get fuel starvation when cornering in one direction. If the sump is on the left end of the tank then on left hand bends, because if you empty the small sump in a long bend then you have severe fuel starvation. A proper swirlpot setup is the only solution, and quite easy to design and construct. Alloy Racing Fabrications do lovely off the shelf swirlpots at very reasonable cost. 1 Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted March 8, 2017 Share Posted March 8, 2017 Here is my little 1l swirl pot. Solved the starvation issues 1 Quote Link to comment Share on other sites More sharing options...
Howsafe Workwear and Safety Equipment Posted March 8, 2017 Share Posted March 8, 2017 Northampton Motorsport did mine recently - did a nice job 1 Quote Link to comment Share on other sites More sharing options...
Cleggy the Spyder Man Posted March 8, 2017 Share Posted March 8, 2017 On my other account but here's some pics 1 Quote Link to comment Share on other sites More sharing options...
BenD Posted March 9, 2017 Share Posted March 9, 2017 @Cleggy the Spyder Man clarke do you know what low pressure pump was used for your setup. looks like a really neat setup im hoping to achieve something like this Quote Link to comment Share on other sites More sharing options...
XTR2Turbo Posted March 9, 2017 Share Posted March 9, 2017 normally the factory use the redtop suction pumps Quote Link to comment Share on other sites More sharing options...
BenD Posted March 9, 2017 Share Posted March 9, 2017 when its says low pressure how low is low enough 4.5 psi or does it need to be more than that. https://www.merlinmotorsport.co.uk/p/facet-solid-state-electric-fuel-pump-only-1-5-4-0-psi-fac-ss500 would somethign like that do what i need Quote Link to comment Share on other sites More sharing options...
