snowy892 Posted March 2, 2017 Share Posted March 2, 2017 Hi I've got a seiw westy factory build 55 plate. Recently the oil pressure gauge has stopped working, Ive had the oil pressure checked (all ok) Can anyone tell me is the gauge mechanical or electrical? I only ask this as Ive seen gauges for sale mechanical or electrical. As you've probably guessed I haven't a bl**** clue!!! Regards Richard Quote Link to comment Share on other sites More sharing options...
Thrustyjust Posted March 2, 2017 Share Posted March 2, 2017 Potentially a factory built car will have a Ford engine. As a whole, it will be an electric gauge with a VDO gauge and sender. The sender on the Ford block is on the drivers side near the front and looks like this as a sender. If you have a gauge like this If you have had the oil pressure checked the person doing this would have removed the sender. Quote Link to comment Share on other sites More sharing options...
snowy892 Posted March 2, 2017 Author Share Posted March 2, 2017 thanks for the reply. Do I need a new sender rather than a gauge? Quote Link to comment Share on other sites More sharing options...
Thrustyjust Posted March 2, 2017 Share Posted March 2, 2017 If you disconnect the wire on the sender and earth it to the block, the gauge should go to maximum, with ignition on. If it does then the sender is at fault. If it doesnt move, then it could be the wire from sender to gauge, the live feed to the gauge or the gauge itself. Quote Link to comment Share on other sites More sharing options...
Quinten Posted March 2, 2017 Share Posted March 2, 2017 I'm really sorry to somewhat barge in on a thread, but this question is rather apt, and raises a question for me as well. On my previous engine, a Crossflow, I only had an oil pressure warning light, no gauge. My new Zetec has the above mentioned sensor in the block and now I am wondering, will that only work with a gauge, or also on the light? Quote Link to comment Share on other sites More sharing options...
Thrustyjust Posted March 2, 2017 Share Posted March 2, 2017 4 minutes ago, Quinten Uijldert - Northants AO said: I'm really sorry to somewhat barge in on a thread, but this question is rather apt, and raises a question for me as well. On my previous engine, a Crossflow, I only had an oil pressure warning light, no gauge. My new Zetec has the above mentioned sensor in the block and now I am wondering, will that only work with a gauge, or also on the light? Quinten, you will need a dual switch , that has a variable for the gauge and a switch for the light. 1 Quote Link to comment Share on other sites More sharing options...
Quinten Posted March 3, 2017 Share Posted March 3, 2017 @Thrustyjust brilliant, I will try to get one in pronto... getting to the end of my conversion! Quote Link to comment Share on other sites More sharing options...
Quinten Posted March 3, 2017 Share Posted March 3, 2017 Oh bother... there are so many of them... Any clues what sort of pressure I should be buying it for? (180bhp Silvertop Zetec) Quote Link to comment Share on other sites More sharing options...
Andy (Sycho) Posted March 3, 2017 Share Posted March 3, 2017 1 minute ago, Quinten Uijldert - Northants AO said: Oh bother... there are so many of them... Any clues what sort of pressure I should be buying it for? (180bhp Silvertop Zetec) It should be wrote on the one you have. Quote Link to comment Share on other sites More sharing options...
Quinten Posted March 3, 2017 Share Posted March 3, 2017 2 minutes ago, Sycho said: It should be wrote on the one you have. Would that not be only applicable to the gauge value? I need to find out for the light... Quote Link to comment Share on other sites More sharing options...
Thrustyjust Posted March 3, 2017 Share Posted March 3, 2017 You need to match the sender to the guage too, as it will have a resistive variable internally and that must be the range the gauge is looking for. Anything with a switch change at 15 psi should be enough for a Zetec. 1 Quote Link to comment Share on other sites More sharing options...
Quinten Posted March 3, 2017 Share Posted March 3, 2017 As I don't have a gauge; mine are VDO Cockpit in White, so not so common; maybe I should instead replace it with a single switched value? Or maybe add a second sensor instead of replacing it? Thought I was passed all the issues now Quote Link to comment Share on other sites More sharing options...
Thrustyjust Posted March 3, 2017 Share Posted March 3, 2017 5 hours ago, Quinten Uijldert - Northants AO said: As I don't have a gauge; mine are VDO Cockpit in White, so not so common; maybe I should instead replace it with a single switched value? Or maybe add a second sensor instead of replacing it? Thought I was passed all the issues now So you need a VDO sender like this then https://www.merlinmotorsport.co.uk/p/vdo-pressure-sender-5-bar-1-8npt-with-low-warning-360081030086 Quote Link to comment Share on other sites More sharing options...
Quinten Posted March 3, 2017 Share Posted March 3, 2017 32 minutes ago, Thrustyjust said: So you need a VDO sender like this then https://www.merlinmotorsport.co.uk/p/vdo-pressure-sender-5-bar-1-8npt-with-low-warning-360081030086 Yes, indeed. Having spoken briefly to Steve at NMS, he reckons I should have a 10 bar gauge, and 1 bar warning light threshold. And 1/8NPT thread? Quote Link to comment Share on other sites More sharing options...
Thrustyjust Posted March 3, 2017 Share Posted March 3, 2017 10 bar gauge is a bit ott. Thats 150 psi oil pressure !! Zetecs dont go anywhere near that. Quote Link to comment Share on other sites More sharing options...
