It is the same on my duratec engined car, there is a small triangular gusset welded in the front corner of the chasis, it bolts through a hole drilled in that plate.
Any photos? Just interested to see what's possible!
I was told it was because of the torque rotation agsin due to engine mounts being low.
No problem, unfortunately my engine isn't fitted at the moment, so the picture is only of the brace but it should give you an idea.
Bear in mind, my engine is mounted at 10degrees so only needs one brace, other duratec engined cars and the ecoboost cars have this replicated on the other side of the chassis.
708E840E-9481-4AFB-AB69-8BE09C3AF4CA_zps
66698BED-7832-4877-B3A4-A65044B7CC4C_zps
Interesting photo I might weld these in just in case I change my design which uses the original top mount on the 1.6 engine with a cross brace
It may be worthwhile, what you can't see on the photo, (if you didnt already know) on the engine end of the brace, westfield just install a normal suspension metalastic bush to allow a small amount of movement.
I can take a picture of mine if you want one.
Mike
Mike
I have pictures of the brace but I did not realise they had welded in triangular plates
I think my brace is likely to be ok but worth considering
Thanks for the photos, good idea.
My chassis doesn't have those triangular brackets unfortunately ☹️
Andy
