Terry Everall Posted November 3, 2015 Posted November 3, 2015 I have a DrayTek router and we only have about 3MB/sec broadband speed. I was talking to someone the other day and they said I should locate the router as close as possible to the BT main socket coming into the house and it would then speed up the broadband/WiFi a bit At the moment the router is in another room and has about 6 to 7m of telephone wire feeding the router Would you move it? Quote
pistonbroke Posted November 3, 2015 Posted November 3, 2015 Doubt 6/7 mtrs would have that much effect on speed tbh the fact its wireless will slow down more , wireless router gives a delay when its processing the signal , but that causes "lag" more than reducing overall speed . Quote
CraigHew Posted November 3, 2015 Posted November 3, 2015 Well if you're having problems I'd try and move it to see the difference. I used to have my home office downstairs in the room where the master socket was located. When I relocated to a spare upstairs room, I left the modem where it was and used Powerline adapters to get this LAN around my house very sucessfully. Quote
Paul Hurdsfield - Joint Manchester AO Posted November 4, 2015 Posted November 4, 2015 3mb !!! I bet they get faster than that at the North Pole.....lol Quote
Terry Everall Posted November 4, 2015 Author Posted November 4, 2015 Its sometimes only 2Ms/s !!!!!! and i live on edge of York Quote
Stuart Posted November 4, 2015 Posted November 4, 2015 I only get 1.9 Mb/s just outside Worcester. We might as well be on the north pole 'cos there's no chance of cable/fibre as not enough punters on the exchange (but there are enough to make the BT line groan under the strain). Just bought myself a Billion router so I can have a play with the SNR on the line see if I can tweak it up a bit Quote
corsechris Posted November 5, 2015 Posted November 5, 2015 We typically get those sort of numbers on the ADSL lines at work as we are a fair way from the nearest exchange and the copper bundle is in a poor state. Good job we also have a 10G Raman link or two coming onto site. At home, I fitted one of those BT Openreach style master sockets that has the filter built in. Main benefit is it isolates the rest of your phone wiring from the main incoming line so you can get a lot less HF attenuation as a result, so often better link speeds. Also means you don't need filters on all the other sockets in the house assuming you still have POTS kit plugged in that is. Not wanting to rub it in, but I usually see 18MBPS data rates at home. Always see a link speed around 20MBPS. About 200m from the exchange as the wire runs, direct link. Quaint old setup, but it does mean I still can't get FFTC as there's no 'C' yet, even though the rest of the village is done. Quote
Paul Hurdsfield - Joint Manchester AO Posted November 5, 2015 Posted November 5, 2015 Oh well if we are bragging, i have B T infinity up to 40 mb and usually get 38/39mb....lol Quote
Blatman Posted November 5, 2015 Posted November 5, 2015 I'm about to have a 1Gb internet connection installed at home And I agree, a few meters of extension cable inside the house will make naff all difference to the speed of the connection. A new BT master socket with a built in filter may help. You might also want to try one of these: http://www.broadbandbuyer.co.uk/products/7256-british-telecom-iplate/ Quote
Andy Banks Posted November 5, 2015 Posted November 5, 2015 What Blatters says, made a little bit of difference to my feeble ADSL and at 3-4mbps it really helps. Quote
Terry Everall Posted November 6, 2015 Author Posted November 6, 2015 I have moved the router now and will get an Iplate. Do you mean get a NEW BT master socket rather than fit the iplate to my existing socket? I do not have any extension phones Quote
SootySport Posted November 6, 2015 Posted November 6, 2015 An i plate will not make any difference as you don't have any extention cabling. If you want to keep the router & long lead (RJ11) where it is now you do need a good lead from the filter to router. It needs to be twisted pairs and screened, the Belkin leads are particularly good. Quote
Terry Everall Posted November 6, 2015 Author Posted November 6, 2015 The router is now plugged directly into the filter attached to the main incoming socket Quote
corsechris Posted November 6, 2015 Posted November 6, 2015 Oh well if we are bragging, i have B T infinity up to 40 mb and usually get 38/39mb....lol Wasn't bragging, more just wanting to say that ADSL2+ can achieve the advertised rates in the real world if conditions are favorable. At my last place I was also close to the exchange and usually got close to maximum numbers. If you do have any internal extension wiring an 'I' plate would probably help a bit - effectively the same as using a new Openreach style master socket really although apparently the filters on the Openreach box are supposed to be better? If you don't have any extension wiring then it's unlikely to do anything much. Always worth checking you have a quiet line if the BB is a bit slow. Quote
Paul Hurdsfield - Joint Manchester AO Posted November 6, 2015 Posted November 6, 2015 And I was only joking..... Quote
