Any contacts for custom exhausts?
I've contacted a number of companies detailing my requirements for an exhaust system in order to try and get a rough idea of cost and not had a single response.
Anyone have any contacts on here I could talk to in order to get a good idea if cost.
I essentially have 2x options. Underslung or twin external silencers.
Thanks in advance if you can help
Phil brad in tamworth staffs do bespoke systems
Thanks BAF,
Is this someone you've dealt with personally? Is he familiar with Westfields?
I know it's a fair old way, but JP Exhausts in Macclesfield have done some cracking work over the years; they also did the bespoke system for Barry's big Chevrolet engined Westfield - I remember seeing it up on the ramps when I called in to pick up a collector they'd modified for me.
Thanks Dave,
The issue I'll have is that I will need to trailer/truck the car to a exhaust builder as the car won't be drive able. Therefore I really want to get an idea of costing beforehand.
I've sent out drawings as well as descriptions and not one reply :(
I used him once,only for a link pipe though
He was building a system up on a marcos race car - The manifolds were a work of art
Apparently he does/did quite a bit for the factory
I use and recommend http://www.haywardandscott.com/ in Basildon.  They will make anything in the exhaust dept.  form straightforward stainless pipes to highly polished intricate manifolds and boxes.   Anything custom is going to cost yer of course.
With an underslung exhaust every speedbump will be you enemy.
I'd like to call it my 'Sump' protector :d
Thanks Sooty,
I'll try and contact them and see if they respond.
I'll try contacting him and see if I get a reply.
:yes:
Based on your location I would try Paul Gooderham http://www.paulgooderham.co.uk/automotive-metal-work
Thanks Mark,
I did speak to Paul in February this year but he said he was unable to help.
Thanks Mark,
have you also tried Andy Bates at AB Performance? He's also not too far away from you in Suffolk.
http://www.abperformance.co.uk/services.aspx?cat=15
Thanks again Mark,
Yes tried them too. They are one of the ones who haven't replied to my Email.
Thanks again Mark,
Andy's a pretty busy man, you may be better to telephone him to discuss options.
Thanks again Mark,
I'll try and ring him tomorrow and see what he says.
:yes:
