December 2023
Quinten
December 16th, 2023
Spend: £0.00
Using the Enterprise Bold Italic font and Fusion 360, I created a copy of the Westfield badge that @Marcus Barlow - Show and Events Co-ordinator used to sell and printed it on my 3D printer (.STL attached).  Brass screw inserts sit on the back and then some thin aluminium was used to create tabs that hook into the back of the grille.
A few coats of primer followed by gold paint and lacquer makes it look convincingly metal ;)
December 22nd, 2023
Spend: £140
Picked up my side panels from Mark at Carbon NV and popped into next door's unit where Martin at Ro-Fit & MH Auto Services runs the bodyshop.  Dropped off my nose cone to have a professional painted nose band on it.
December 24rd, 2023
Spend: £0.00
Sprayed the radiator and surround black so they will be less visible behind the grille.
December 30th, 2023
Spend: £0.00
Point of no return...  cutting the bodywork to fit my new side panels
Then fabricated a small plate to close off the hole between pedal box and body.
And then cut the side panel to fit as I'm keeping the bonnet locating blocks.
Last month: £  5346.94
This month: £   140.00
Total:      £  5486.94
Westfield.stl
0 Comments
Recommended Comments
There are no comments to display.
