KugaWestie's Blog
  • entries
    8
  • comments
    47
  • views
    17,284
15 Comments
Recommended Comments
Tyson
Good job well done.............Is that a ghost i can see in the third photo????
KugaWestie
Thanks Brian
What you can see is the seat!!
deanoecosse
Thats a great job Gary. It's one of those fairly small jobs but makes a huge difference. I'm sure we've all spent time strapping the harnesses on and then find our damn near side mirror needs adjusted, then we have to go through all the PITA faffing about getting unbelted, adjusting, rebelting etc. Thats me got a new job on my winter list now.
What sort of price did you pay for the mirrors?
alexander72
good work!!!
KugaWestie
Thanks Dean
The total cost for the job was less than £50
I paid £30 for the mirrors on EBay - just bided my time. Also if you are going to spray them anyway then you can be less selective and buy cheap.
The control switch was £6 on EBay
Can of grey primer - £6
Can of gloss black - £6
A good upgrade for less than fifty notes!
s2rrr
Hi Gary now that I have found the blog I will ask the question, is the wiring simple and/or do you have a sketch of the way its done.
Bob
Ferry Ritstier
Looks great are they also heated?
Ferry
KugaWestie
Ferry - yes they can be heated, but I didnt bother wiring the elements in, I dont think I will ever use them heated. There are only two cables per mirror for the heating element, so it would be easy enough to do
KugaWestie
Here is the wiring detail
s2rrr
Computer says I don't have permission to open that pdf any advice would be welcome.
Bob
KugaWestie
Electric Mirror Wiring
Nearside Mirror (Passenger)
2 x Black Cables Heated Glass
White Cable Connect to Black and Yellow cable on switch
Grey Cable Connect to Black and Blue cable on switch
Blue and Brown Cables Join together and Connect to Grey and White cable on switch
Offside Mirror (Driver)
Blue Cable Connect to Black and Lilac cable on switch
Brown Cable Connect to Black and Brown cable on switch
White and Grey Cables Join together and Connect to Grey and White cable on switch
Switch
Green Fused or switched live feed
Black Earth
s2rrr
Thanks Gary spot on, will print it all out tomorrow.
Bob
KugaWestie
No problem Bob - good luck with it
Upgradeitus - bad disease isnt it!!!
s2rrr
Gary, juts in case any one else reads this. I have just received my brand new boxed mirrors from a place on Ebay £39 the pair, for some reason one is dearer than the other. Can't get much better than that, now I have to sort out some time to fit them.
Thanks for the help
Bob
Dave Eastwood (Gadgetman)
Just finished the same upgrade, Got a package of wing mirrors and a switch from an MGF, unfortunately none of the eBay switches had the connector with them, so I ended up visiting a local scrappy for that. (The switch is from a Rover 200, MGF possibly MG TF and mk 1 Landrover Freelander, may also be used on mk 1/2 Discoveries). Mine came from a Freelander that had been in a fire, fortunately the switch/connector and 30 cm of loom were untouched.
The mirror fit was interesting, IIRC the mirrors are common to the Rover 200 too, not sure if they align any better, but the MGF mirrors mounting posts were so far out they were never going to screw into the Westfield uprights without pointing upwards at 45º.
In the end, I stripped the mirrors right down and removed the cast aluminium locking pin that connects the base to the mirror housing. It has two ridges that lock into the housing to align them both. A few minutes with the Dremmel soon took most of the ridges off. Drilling the hole the pin fits through slightly oversize allows the mirror housing to rotate on the base.
After reassembling the mirrors and setting the right alignment on the car, I then just Epoxied the locking pins into position in their new orientation.
Job done, mirrors now point in the right direction!
