MBE 956 ECU & Loom
MBE 956 ECU & Loom for sale. purchased this from a member on here when I thought I was having problems with the loom in my car, in the end it turned out to be something much simpler, so I never had to use this.
The loom came off a Zetec(Silvertop I believe), although apparently the connectors were different on my Blacktop, so double check the connections you need, or be prepared to swap them if need be.
Although I never ended up fitting it, I did change the map on the ECU to the one for my car, so the map is for a 2ltr standard Blacktop with Jenveys/Raceline exhaust system with no CAT, as mapped by Northampton Motorsport.
I paid £150, so just looking to make my money back.
There is 1 of these connectors:
2 of these:
and 4 of these:
Wire marked Main Harness has been cut:
and wire marked Coil has had a spliced wire cut:
and finally, wire marked Water temp has no connector on it as well, didn't take a photo of this as it just ends in cut wire!
Pm on the way
Sold!
Geoff
You will be asking for my throttle bodies next !
Not for me sadly Chris - for my mate building the Haynes Roadster.
I thought you were still collecting items for your silvertop conversion
