darve Posted November 22, 2012 Share Posted November 22, 2012 Hi guys Due to a change in circumstances I have had to make the difficult choice to part with my ST170. Only reason I'm selling is to get a dirt cheap run around with very low running costs I have a soft spot for this car so it's a shame to have to see it go. It's a 52 plate ford focus st170 but currently has a private plate on which can either go to the seller or I'll will change back to the standard one if they would prefer. As you can see from the pictures she is in good condition on the outside. The drivers seat material has separated at the joint on the drivers side on the back support. As this is on the joint, not an actual tear, then it will be an easy fix if your handy with a needle and thread! The car is very easy to drive, has lots of umf, and sticks to the road quite well MOT until May 2013 Taxed until end of Nov 2012 Current mileage circa 104k. This will go up slightly as I will continuing to use the car to get to and from work. The engine management light is on as it has the following fault codes: P0133 O2 circut slow respnse bank 1 sensor 1 - front lambda sensor before the CAT needs replacing. Cheap and easy to do with a 22mm spanner P1518 intake manifold runner control stuck open - this seems to be intermitant as the car performs the same as before the EML came on. If you google the fault code it seems to be an easy fix. I unfortunately do not have the time to sort this right now. Due to needing to shift this quickly and the above fault codes - I'm pricing it to you guys or your friends/family for £1,500. if you do a quick bit of research you'll see this is a steal of a price. I would like to advertise at a higher price but I need to get hold of the cash ASAP. The car is located in south Essex PM me on here or contact me on 07554 019003 I may not be able to answer the phone as I'm often in client meetings. Leave a message and I'll get back to you. Thanks for looking Dave Link to comment Share on other sites More sharing options...
darve Posted November 24, 2012 Author Share Posted November 24, 2012 now sold Link to comment Share on other sites More sharing options...
