Self Cancelling Indicators
Me too
Also very intrested as that is part of the winter upgrades.
I found a use for my old lights - made a test board...
IMG_20150920_161919031_HDR_zpskzdop9lj.j
Please send me a copy
rich8977@gmail.com
Hi Rich, I'm afraid I don't have a copy of Ian's circuit - this is a new design by me, using a programmable ATTiny85 micro for more 'logical' operations.
With a toggle switch, it will turn the indicator off IF (time since turned on > x AND time since brake release > y) OR switch is off.
With a push button, it will turn the indicator off  IF (time since turned on > x AND time since brake release > y) OR same direction button is pressed again OR opposite direction button is pressed.
Very similar to the Westfield self-cancelling indicator, but with a brake input to inhibit the off, plus the option of using with a Lucas style toggle switch.
You never fail to impress me Mike :d
Me too!
Watching this with interest.  :t-up:
Thanks Dave, it helps that you're easily impressed...
I have a new hobby - counting indicator flashes while I drive to work!
I reckon x = 12 and y = 6 sec works well - I'll probably try this and a dip switch selectable alternative of x = 15 and y = 9 sec.
PCB design is finished - will order a batch for testing next...
I'm happy to test one if you have a spare  :d
I don't believe your car exists, John :)
Please send me a copy too.
shedless@googlemail.com
Thanks.
my self cancelling ones use a push button. press for one second and i think you get 3 flashes, 2 seconds its 5 flashes, and 3 seconds they stay on till you press again. tbh this needs to be more. i'm forever pressing the button so I would say your 12 flashes is probably about right. but if I read it right it will be doing 2 flashes per second which seems a bit fast.
I'm liking the 'brake' on option - very sensible, will be interested in this!
 Hah :) ! Look on the Classic Car Tours International facebook page for pictures! - Just got back from the Angouleme Circuit Des Ramparts trip with them. Fantastic event! About 1500 miles in total.
