Mike Rowland - Essex AO Posted October 31, 2015 Posted October 31, 2015 Hooray, msisleman and de04* (Craig and Dean) have fitted their BlinkStops. Craig's worked immediately, but Dean found he had to change his flasher relay from the CBS blue one to the red one (BlinkStop should only add approx 0.1 Ohm, but it seems this tipped him over an edge and stopped the flash working) : Dean has LED indicators all around, so I'm surprised it was OK before, but anyway, the red 30W 'LED' relay (electronic) has solved that problem (strangely the pins are apparently reversed too)... Craig has a voltage backfeed from his Hazard circuit during ignition off (separate Hazard and Flasher relays), but we can fix that one easily enough with the second pole of the hazard switch Road testing starts tomorrow! Meanwhile, the new PCB's have shipped from the factory and I've ordered a huge pile of components on the credit card... I also updated the fitting instructions based on feedback from here and Dean and Craig's experience: http://forum.wscc.co.uk/forum/index.php?app=core&module=attach§ion=attach&attach_id=794 2 Quote
msisleman Posted October 31, 2015 Posted October 31, 2015 Looking forward to road testing tomorrow. The garage testing so far pleases me very much! 1 Quote
Mike Rowland - Essex AO Posted October 31, 2015 Posted October 31, 2015 Here's Dean's switch wiring [strangely his right and left were backwards so he had to rotate the switch - I'll triple check the code]: and he found a convenient brake light wire in the tunnel: Quote
clansman Posted October 31, 2015 Posted October 31, 2015 I'll have a kit please Mike.....Blinkstop that is 1 Quote
DE04* Posted November 1, 2015 Posted November 1, 2015 R7 WSC (Mike) has done a brilliant job in designing and making these,they are so easy to fit. 2 Quote
TableLeg Posted November 1, 2015 Posted November 1, 2015 R7 WSC (Mike) has done a brilliant job in designing and making these,they are so easy to fit. I second that! He's done a fantastic job, using not only his skills and knowledge but his time and all for the good of other Westfield owners. :yes: 1 Quote
Mike Rowland - Essex AO Posted November 1, 2015 Posted November 1, 2015 Aw, shucks - you'll embarrass me now... 1 Quote
msisleman Posted November 1, 2015 Posted November 1, 2015 I can confirm, after todays testing.... Blinkstop has changed my life. 1 Quote
msisleman Posted November 1, 2015 Posted November 1, 2015 Seriously though, it's great. The times all seem sensible enough, and everything works (apart from the ignition off hazard issue as mentioned earlier, we'll sort that). No point not having one in my opinion. Also using buttons on the wheel really is so much better than a dash toggle switch! Quote
Mike Rowland - Essex AO Posted November 1, 2015 Posted November 1, 2015 For those who are interested in the kit assembly (go on, you know it makes sense), here is the first draft of the instructions. It'll be updated to match the PCB's when they arrive as I'll need to solder up the first couple for checks: http://forum.wscc.co.uk/forum/index.php?app=core&module=attach§ion=attach&attach_id=795 Please can you look to see if it makes some kind of sense and whether you now feel more/less confident in having a go... Quote
Mike Rowland - Essex AO Posted November 1, 2015 Posted November 1, 2015 No point not having one in my opinion. Also using buttons on the wheel really is so much better than a dash toggle switch I should maybe point out that if you look at the photo of Dean's install, you'll see that for a toggle switch, all you'd need to do to return the wiring to 'standard' is unplug the 3 switch wires and reconnect to the flasher. That's deliberate in case people are nervous of fitting electronics to an otherwise 'mechanical' system and want an easy way back... Quote
Mike Rowland - Essex AO Posted November 2, 2015 Posted November 2, 2015 Almost finished testing now, just need some slightly less foggy weather... Ooh, and pretty labels arrived 1 Quote
Rich8977 Posted November 2, 2015 Posted November 2, 2015 Hi Mike Looks a cracking bit of kit, can you let me know how much the finished article is and method of payment, I can add it to my list of jobs for the winter, growing by the minute. Regards Rich Quote
Mike Rowland - Essex AO Posted November 3, 2015 Posted November 3, 2015 And here is the finished article - this is what an evening's work with a kit should produce (without the red woolly jumper ): I reckon it would make a perfect Christmas present (well better than socks, anyway!) Now the prices: For non-members, a kit will be £25+postage or £55+postage for a pre-assembled and tested unit. For WSCC members, take 10% off this, so a kit will be £22.50+postage or £49.50+postage for a pre-assembled and tested unit. If there are a few members from one area, I can obviously combine postage. As far as logistics, I should have 7 complete units ready next week. For the kits, I'm waiting on PCB's, but I was able to increase the order from 10 to 20 boards and I'll be soldering up the first 2 (at least) to take new photos for the instructions, so there should be plenty to go around... I've made a note of the order people popped up in, so if you'd like to order one, please send an email to my private address (in the contact area of the fitting instructions) with your forum name and we can go from there! [i'm away on business for a few days, so please don't worry if you don't hear from me immediately] Thanks again to everyone for the kind words of support - it's helped enormously since I didn't quite realise how many hours I'd end up devoting to this one I'll keep the latest version of instructions here: http://forum.wscc.co.uk/forum/index.php/blog/13/entry-280-self-cancelling-indicator-blinkstop/ 3 Quote
Mike Rowland - Essex AO Posted November 8, 2015 Posted November 8, 2015 Meanwhile, back in the BlinkStop factory, the soldering iron has been smoking away... The new PCB's have arrived, too -so I'll solder a few up to finish the assembly instructions this week. I'll start contacting everyone soon to arrange delivery, thanks! 3 Quote
