dirty diamond Posted June 20, 2012 Share Posted June 20, 2012 Hi all, just wondering which is the best gearbox to fit in a pre-lit. I seem to recall someone telling me the type 9 was the slimmest but there seems to be a lot more mt 75's at a more reasonable cos.t Also I notice westfield do remote for the mt 75 but i havent seen one for the type 9. Any advice would be gratefully recieved. dd Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted June 20, 2012 Share Posted June 20, 2012 Westfield built a new version of the chassis with a wider transmission tunnel when it introduced the MT75 gearboxes to it's cars I'm afraid. When the Prelit chassis was designed, even the Type 9 was almost considered a "new" gear box! So really, it's a Type 9 or a four speed. What's in at the moment? cause even that will affect how much work is needed to fit a Type 9. Quote Link to comment Share on other sites More sharing options...
dirty diamond Posted June 20, 2012 Author Share Posted June 20, 2012 Thanks Gadgetman, the 4 speed I have in at the moment has the reverse next to first gear but I don't know what type it is, regards, dd Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted June 20, 2012 Share Posted June 20, 2012 There's some handy pictures of the different Ford 'boxes and info about them at Burton's http://www.burtonpower.com/parts-by-fitment-type/parts-by-gearbox-all.html Quote Link to comment Share on other sites More sharing options...
Captain Colonial Posted June 20, 2012 Share Posted June 20, 2012 If you go on to the Burton Power web site, they have an excellent transmission guide. Sounds like a Type E. Quote Link to comment Share on other sites More sharing options...
Captain Colonial Posted June 20, 2012 Share Posted June 20, 2012 Curse you, Gadgetman! Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted June 20, 2012 Share Posted June 20, 2012 Quote Link to comment Share on other sites More sharing options...
Pistol Pete Posted June 20, 2012 Share Posted June 20, 2012 Your current four speed is most likely a Type 3 or Type E, changing to a type 9 from the the Type E is a staight swap but the geabox mount requires moving back, for the Type 3 it is a little more costly as the bellhousing, clutch, crb and crb will also require changing (but not the mount). Personally it may be worth looking at a BGH close ratio 4 speed box unless you really really want a fifth gear. They also do 5 speeds boxes but then the price rises quite a bit. This would still require the above work but really does suit a westy much better than a standard ratio box. Quote Link to comment Share on other sites More sharing options...
Mid life crisis Posted June 20, 2012 Share Posted June 20, 2012 If you keep your fingers crossed and the wind blows in the right direction it may be a rocket box, in which case you could fit Quaife straight cut close ratio gears, that would transform your car Quote Link to comment Share on other sites More sharing options...
Pistol Pete Posted June 20, 2012 Share Posted June 20, 2012 As far as I can tell (from research) the term 'Rocket Box' was slang used for the competition ratio box based on the Type E box. Quote Link to comment Share on other sites More sharing options...
Neil2008 Posted June 20, 2012 Share Posted June 20, 2012 I've got a Pre-Lit fitted with a 1700 xflow and type 9 which you're welcome to look at. Or if you're not local I'm happy to photograph. I live in South Bucks. Quote Link to comment Share on other sites More sharing options...
Mid life crisis Posted June 21, 2012 Share Posted June 21, 2012 Quite right Pistol, a close ratio version of the type E. Not sure if they had any further mods though. Quote Link to comment Share on other sites More sharing options...
Evo,s 7SE Posted June 21, 2012 Share Posted June 21, 2012 i wouldnt bother with a five speed unless your doing a lot of motorway miles some good ratios will transform the car i run a 4.1 diff 205/60/13 tyres and that gives 123mph at 7500rpm dont think you would want to go faster than that type 9 is about 12kg heavier as well Quote Link to comment Share on other sites More sharing options...
