Drilled Holes In Rollbar - Question For You Racers
Hi,
I just had a query from Soft Bits for 7's about the turnbuckles I have mounted on my rear stays that are fixed by rivets in holes drilled into the bar. They were asking if this set-up would pass scrutineering? I don't know for what specific racing at present. Any thoughts?
afaik you cannot drill roll bars thats what i have allways been told ,so i have never drilled them ,when folk mount rear view mirrors to full cages they are never drilled and screwed or riveted they are allways held on with either a propa mount or tie wraps ,jubilee clips,bailing string ,anything but drilled ,i know its extreme but by drilling it you are adding a weak point
I was going to drill some holes in mine this weekend?
Totally agree.
By drilling the roll bar, you are weakening the metal more than you think and should the unthinkable happen, you will need all the strength the roll bar is designed to afford.
Do not drill it.
you have to have a hole drilled in it so they can check the thickness of the bar sure it was in blue book
may be wrong though
I think you'll find that a lot of roll cages are actually required to have inspection holes in the bars for scrutineers to inspect the wall thickness. I've seen 1/8" or 5mm specified.
Still doesn't sound like a good idea though.
The only place I have drilled mine is the plates that are welded on the sides for mirrors. Don't drill it. I am sure you could come up with some clamp arrangement. First time I heard about inspection holes but then I am not a competitor. However there's an inspection plate on mine with information pertaining to the approval requirement I think.
Can't recall seeing a hole, for inspection or otherwise, in my cage.
I agree drilling a hole in one of the main tubes is foolhardy. Different drilling a hole for your wing mirrors in the plate provided for that purpose.
I thought that most bars/cages were now certified so would not need a hole drilled?
Personally i'd not be drilling one!
yes cages are certified, any modification like drilling a hole would need to be done by the OEM of the cage and be re tested, otherwise its scrap metal
Thanks guys. I'll pass the comments over to SoftBits.
Where in the blue book does It say don't drill any holes
My old rac type bar had a inspection hole and Allen key fitted.
Strength loss from a small hole Is hardly going cause a safety issue.
If it is certified,Then it would null that I guess.
if you change the bar/cage in anyway ie weld bracket's to it or drill holes in it you have changed it from the design submitted to the FIA/MSA so any certification it had would be void
having said that if all your doing is sprinting or hill's in a road going class you don't need a certified bar anyway
Nick at Soft Bits has said he will supply y-pieces for the rear straps with a long strap as standard so that they can be fixed around the rear stays mounts or similar so no need to drill the stays for those who need to pass scrutineering. :t-up:
As much as it isn't the greatest idea, it is only a small hole and the cage has a factor of safety built into it.
In addition, you have a fastner going through the hole so lines of stress can be conducted thusly and no concentrators are apparent.
Remember also that your chassis is full of holes.
I can't see why you'd be knocked back by scrutineering or why you should worry.
