Throttle bodies, MBE ECU, Loom, filter, FPR
A pile of goodies from an ex grasstrack Duratec 235bhp engine:
Throttle bodies
45mm DCOE type bodies, 88mm long.  Complete with anodised alloy linkages, fuel rail, 90mm alloy trumpets (one has been a bit bashed at the lip and straightened, but is functional), Colvern throttle pot.  These are Australian made bodies from’ EFI Hardware’, bit chunkier than the equivalent Jenveys, but do the job.
SOLD
Injectors
Set of four Weber Marelli Pico injectors, 330cc at 3 Bar, high impedance
SOLD
Air filter
Pipercross foam air filter with fibreglass baseplate and air temperature sensor.  Baseplate has a few cracks and repairs, the filter has a couple of tears in the outer layer of foam.  All a bit scruffy but usable!
SOLD
Fuel pressure regulator
Weber alloy bodied regulator, 3.5 Bar.
SOLD
ECU
MBE967Eg engine management system with map for 235bhp Duratec using above injection. Usual management of fuel, ignition, sensors, fan, lambda, launch, traction etc.
SOLD
Loom
LM967 RWD – Professional rear wheel drive loom for MBE with all connectors and relays.  Plug and play, saves a vast amount of time in producing a neat and reliable wiring setup.
SOLD
Duratec ported cylinder head, cams, inlet
A complete Duratec cylinder head, ported by BPJ Performance with QED Q460 cams (296 degree), adjustable verniers, race springs and standard valves.  Complete with a matched alloy inlet manifold.  This should be capable of delivering at least 250bhp.
£775
Duratec alloy wet sump
SBD alloy baffled sump (SMP-5K-duracat), unmarked hasn’t been bottomed-out.  Complete with standard dipstick and tube.
SOLD
Duratec crank pulley
Standard steel pulley but with machined keyway.
£10
Twin plate clutch
Superclutch 700 Series 7 ¼” twin-plate clutch with sintered plates in good condition.
SOLD
All plus postage.
I can supply photos of all of the bits.  PM me or phone on 07771-722217 for more info.
Stephen
