had my computer for years must be 7/8 years at least its a  dell dimension 9200 whatever one of those is  :blush: and although it works ok  it keeps freezing and sometimes when im on the net the pages gets corrupted with outlook express ,  so I think its time I invested in a new one, as you know i havnt a clue on these things so will require pointing in the right direction as the technical jargon doesnt mean a thing to me   :blush:
quite surprised how cheap they are to buy so looking at somewhere like here what would you recommend, other than the net and uploading my wesite and bookwork (excell)  i dont really do anything else on a computer  :oops: wouldnt mind a better monitor while im on, business will be footing the bill but dont want to go overboard spending   :t-up:
http://www.pcworld.co.uk/gbuk....ia.html
  • Replies 58
  • JeffC
    22
  • Captain Colonial
    15
  • Dibby
    7
  • Pilot Pete
    3
Popular Days
If a PC keeps freezing, buying a new one is not really the most cost effective answer. Cleaning up the old one or re-installing the software is where I would begin unless you really want a new one?
Pete has wiped this one about 3 times now John and it is ok once he has done it but I just thought that technology might have moved on in the last 8 years or so since i got this one and should maybe invest in a better machine  :suspect:  ???
quick look on google this is what i have now  ??? which might as well be in chinese for what i understand of it  :durr:
Manuals
Back to Contents Page
Specifications
Dell™ Dimension™ 9200 Service Manual
Processor
Processor type
Intel® Pentium® 4
Intel® Pentium® D
Intel® Core™ 2 Duo
Level 2 (L2) Cache
at least 2 MB on Intel Pentium D, Pentium 4, and Core processors
Memory
Type
dual-channel 533-, 667-, and 800-MHz DDR2
Memory connectors
four
Memory capacities
512 MB or 1 GB
Maximum memory
4 GB
BIOS address
F0000h
Computer Information
Chipset
Intel P965 Express Chipset
DMA channels
eight
Interrupt levels
24
BIOS chip (NVRAM)
4 MB
NIC
Integrated Intel 82566DC Gigabit Network Connection
System clock
800- or 1066-MHz data rate (depending on your processor)
Video
Type
PCI Express
Audio
Type
Sigmatel 9227 audio codec
Internal 7.1 channel or PCI option cards
Expansion Bus
Bus type
PCI 32-bit (PCI Specification 2.2)
PCI Express x1, x4, and x16 (PCI express 1.1a)
Bus speed
PCI: 33 MHz
PCI Express:100 MHz
Bus throughput
PCI Express:
x1 slot bidirectional speed - 500 MB/s
x4 slot bidirectional speed - 2 GB/s
x16 slot bidirectional speed - 8 GB/s
PCI
connectors
three
connector size
120 pins
connector data width (maximum)
32 bits
PCI Express (x1)
connector
one x1
connector size
36 pins
1 PCI Express lane
PCI Express (x4)
connector
one x4 (x8 connector wired as x4 electrically)
connector size
98 pins
4 PCI Express lanes
PCI Express (x16)
connector
one x16
connector size
164 pins
16 PCI Express lanes
Drives
Externally accessible:
two 3.5-inch drive bays (FlexBay)
two 5.25-inch drive bays
Available devices
serial ATA drives, floppy drive, Media Card Reader, DVD drive, and DVD/CD-RW combo drive
Internally accessible:
two 3.5-inch hard-drive bays
Connectors
External connectors:
Video (external card)
15-pin VGA connector
28-pin DVI connector
Network adapter
RJ-45 connector
USB
two front-panel, six back-panel, and two internal USB 2.0-compliant connectors.
Audio
seven back-panel connectors for line-in, line-out, microphone, rear surround, side surround, center/subwoofer Low Frequency Effects (LFE) channel, and S/PDIF; two front-panel connectors for headphones/microphone
System board connectors:
Serial ATA
six 7-pin connectors
FlexBay Drive
USB 9-pin header for optional Media Card Reader (3.5-inch bay devices)
Fan
5-pin connectors
PCI
three 120-pin connectors
PCI Express x1
36-pin connector
PCI Express x4 /x8
98-pin connector
PCI Express x16
164-pin connector
Thermal sensor 1x2
2-pin connector
PS/2 and serial port connector 2x12
24-pin connector
Floppy
33-pin connector
Controls and Lights
Power control
push button
Power light
green light — Blinking green in sleep state; solid green for power-on state.
amber light — Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see Power Lights).
Hard-drive access light
green
Link integrity light (on integrated network adapter)
green light — A good connection exists between a 10-Mbps network and the computer.
orange light — A good connection exists between a 100-Mbps network and the computer.
off (no light) — The computer is not detecting a physical connection to the network.
Activity light (on integrated network adapter)
yellow light — Blinking indicates activity on the network.
Diagnostic lights
four lights on the front panel (see Diagnostic Lights)
Standby power light
AUXPWR on the system board
Power
DC power supply:
Wattage
375 W
Heat dissipation
1280 BTU/hr
Note: Heat dissapation is calculated based upon the power supply wattage rating.
Voltage (see the safety instructions in the Product Information Guide for important voltage setting information)
90 to 135 V and 180 to 265 V at 50/60 Hz
Backup battery
3-V CR2032 lithium coin cell
Physical
Height
46.05 cm (18.13 in)
Width
18.75 cm (7.38 in)
Depth
45.42 cm (17.88 in)
Weight
12.7 kg (28 lb)
Environmental
Temperature:
Operating
10° to 35°C (50° to 95°F)
Storage
–40° to 65°C (–40° to 149°F)
Relative humidity
20% to 80% (noncondensing)
Maximum vibration:
Operating
0.25 G at 3 to 200 Hz at 0.5 octave/min
Storage
0.5 G at 3 to 200 Hz at 1 octave/min
Maximum shock:
Operating
bottom half-sine pulse with a change in velocity of 20 inches/sec (50.8 cm/sec)
Storage
27-G faired square wave with a velocity change of 200 inches/sec (508 cm/sec)
Altitude:
Operating
–15.2 to 3048 m (–50 to 10,000 ft)
Storage
–15.2 to 10,668 m (–50 to 35,000 ft)
Okey dokey. No point in getting carried away though with spending big. The cheapest one on your link looks OK to me but probably doesnt include a monitor
If it's 7/8 years old then getting a new cheap one will be a good solution and you can load the applications on it as a clean install which will(should) resolve any problems accrued over the years...
this would be my choice of the PC World machines for £330 and you could either get the bundled monitor which adds £120 to the cost or
this is a good 19" monitor for just £64
If you're going for a desktop, a Core i5/ i7 based computer will probably do you well and in terms of memory, the more the merrier. Anything else is a bonus. You won' need all that processor power now but 5 years time with a new version of Windows or Windows 7 with a bazillion updates it will feel less creaky.
Memory and hard drive space has never been cheaper and dead simple to upgrade in the future if you run out of power and space.
PC World is your mass-market PC shop and may not get you as good a deal as getting someone to build one up from scratch, but it's a lot easier to warranty anything that goes wrong. Just don't fall for their upselling of bumph you don't need, like antivirus for only £30, overpriced cables and bundles. Antivirus is free, cables are cheap elsewhere.
TBH I'd go to Dell online and buy whatever's in your budget off them without having to understand the numbers, it'll be a decent deal, they'll give you decent aftersales support
My computer knowledge is pretty poor, and in fairness if you've had the same computer for that long it's clearly not you're uppermost interest.
I usually buy from Dell, they really are just plug and play. I know people slate Dell, but they really have been 100% with me.
Dell has a funny pricing system, you pick what you want, then it asks for more money than it was, it's pretty strange, and obviously people don't like it. However, if you pick a tower that is more expensive/better than you need, you still get a better deal than if you bought the cheapest one and brought the spec up to that level.
The last tower i bough was from ebuyer, a friend set it up once I'd got it. apparently it's pretty good, and a bargain, well it works and does what's needed anyway. 2Fwww.ebuyer.com%2Fproduct%2F251310&h=RAQDtgRtu
If that link doesn't work, then you'll realise how little I do know  :D
Ok, link doesn't work, now there's a supprise  :(  Stiil, people who used to build their own now buy from here due to them being as cheap as you can buy the bits.
Another vote for Dell.  I've got something even older, a Dimension 8300.  The only thing that has failed was the video card, which was outdated anyway and a doddle to change.  Apart from that, nothing (touch wood) has gone wrong.  The original keyboard still works great, good housekeeping on the software means it runs fine, and it outlived the expensive Illyama monitor by two years (got a Dell 24" widescreen for £170 which is superb).
What I like about Dell stuff is the guts of it are so easy to work on when you need to.  A clamshell case that opens easily, cards that click into place without screws, extra slots with extra easy mount clips for future expansion, just a doddle to service and expand in future.  Put in a new 1TB HDD when my old 120Gb HDD was full, couldn't have been easier.
A lot of what people think is their machine getting old is actually software loaded at start up dragging down the memory.  This comes from progressive adding software over the years, which soon starts arguing with each other for resources.  I recommend the free Glarysoft Quick Startup which allows you to disable lots of crap stuff running in the background at system start up (HP printer software, QuickTime, Adobe and others are notorious for loading at start up, and before you know it, it takes ten minutes just to start your computer).  Give that a go and you'll be pleasantly surprised.
Another one for the cleanup is Piniform's CCleaner on free download for home use. Although, I tend to find these cleaners are oif limited value because the cycle of endless updates from Windows and the other prorams, installing and uninstalling stuff leaving residual bumph in the background bogs a system down and it's not as effective as wiping Windows off and starting again - a good idea to do once a year if you want to keep your PC in tip-top condition ... Windows is a bit like the oil in your Westie! Out with the bad oil, in with the good oil, you don't try to 'clean' your oil once a month, you replace it every year.
what the score with monitors then, got a Hp 20" at the mo noticed they do led backlit monitors, are these likely to give you a headache after looking at them for a while  :oops:   :D
Agreed Dibby, use CCleaner as well myself, very effective at tidying up Windows Registry.
If you can stretch to a Mac you wont be dissapointed, they last for years, are fast and don't keep asking "Are You Sure"      Mini Mac is no frills takes up no space and you can use a TV as a monitor.
Is your current one a CRT then?  The backlit LED ones are, for me anyway, less stressful than a CRT one by a long way, and no heat generation either.  Certainly with a good one, a better image and sharper resolution than CRT too.  Make sure you don't go the old-fashioned VGA connection route, though.
