Guest Posted September 22, 2003 Share Posted September 22, 2003 HELLO FOLKS, NEW MEMBER HERE, SPENT ALL SUMMER THRASHING AROUND IN MY V8, NOW I THINK ITS TIME I ACTUALLY DID SOME WORK ON IT! COULD ANYONE TELL ME THE BRAKES USED, DISCS, CALIPERS ETC. SUSPENSION, BALL JOINTS, TRACK RODENDS, STEERING RACK? IT IS A FACTORY BUILT 1993 MODEL. ALLL HELP AND SUGGESTIONS GREATLY APPRECIATED (I SUSPECT I HAVE WORK CUT OUT FOR OVER THE WINTER! CHEERS, MADINZEHEID Quote Link to comment Share on other sites More sharing options...
chazpowerslide Posted September 22, 2003 Share Posted September 22, 2003 Hushhhhhhhhhhhhhhhhhhhh. There is no need to SHOUT!!!!!! You'll wake everybody up. I'm sure one of the V8 chaps will be along in a moment to help/contradict. Discs and pads probhably Ford Cortina (M16 Caliper) or 2.8 Capri if vented (spaced M16 caliper) unless they have been up-graded. Bottom Ball joints (front) probhably Maxi/Cortina Top swivels (front) Transit drag links. Trackrod ends Ford Escort as is the rack. If it has an indipendent rear end the calpiers will be Seirra/Scorpio with Mk 3 Escort front discs. If live axle Escort drum brakes. Ask Westfield for the sizes of the spherical bearings used in the rear suspension or somebody here may know. HTH Chaz Quote Link to comment Share on other sites More sharing options...
S8ight Posted September 22, 2003 Share Posted September 22, 2003 gis a shout if you want any cheap bits. Quote Link to comment Share on other sites More sharing options...
