fatbaldbloke Posted April 23, 2011 Share Posted April 23, 2011 SOLD to a really nice chap from "oop north". I've owned this Westfield for over 5 years, it has been completely rebuilt over that time with a small fortune spent on it. I've covered just over 10000 miles in it so most of the parts that I have replaced have done less than that. It's ready to go, drives superbly, is fast, flexible and reliable. Tax until the end of July, MOT mid-August. I'm a chartered mechanical engineer and have worked in the aircraft industry and for the last 15 years in Formula 1, if that's any indication of the care and quality that's gone into this car. Here's the spec: Model/chassis: 1998 Westfield SEW Body: Carbonmods carbon wheel arch protectors. New Westfield sports seats. Schroth FIA approved turnbuckle harnesses with 3" shoulder straps, FIA approved 2014. Carbon fibre tunnel top with leather gearstick and handbrake gaiters. Carbon fibre pedal cover. Floor mounted pedals. Passenger footrest. Boot box with bespoke mohair cover. Manual fire extinguisher. Side screens and/or perspex wind deflectors. Heater. RAC-type roll bar. New dashboard switches and 12V accessory socket. Racetech gauges and electronic speedo. Steering: Ford Escort rack and pinion. Cortina uprights and hubs. New upper and lower ball joints and trackrod ends. New wheel bearings. Geometry set at Northampton Motorsport Momo detachable suede steering wheel. Suspension: Standard powder coated front wishbones (recently replaced) fitted with polybushes. Coil over steel AVO spring and shock absorber units, 300 lb/in. Rear live axle running a 4.125 open english diff. Coil over steel AVO spring and shock absorber units, 150 lb/in. Wheels & tyres: Front - 6" Minilites with 185/60R13 Yokohama A048 tyres. Rear - 7" Minilites with 205/60R13 Yokohama A048's. Brakes: Front - new Group N Solid discs, Westfield Hi-Spec 4 pot calipers. New flexible hoses. Filled with dot 5 fully synthetic fluid. Rear - 8" drums, single leading shoe, new wheel cylinders. Engine: Zetec "silver top" 2 litre. Head, block and cams currently as standard. Very carefully rebuilt less than 5k ago with low mileage crank, new bearings, oil pump, water pump, seals, timing pulleys, belt and tensioner, valve seals, etc, etc. Shallow sump with revised baffles (Dunnell Engines). Lightened flywheel and heavy duty clutch (Dunnell Engines). ARP rod end bolts. Intermediate spec hydraulic tappets (Dunnell Engines). Carbonmods carbon plug lead cover. Modified cooling system (Dunnell Engines). VW Polo rad with Pacet Profan with thermostatic switch and manual over-ride. Individual throttle bodies (Suzuki GSX-R600). ITG performance air filter. 0.5l oil catchtank. Megasquirt 1 V3 ECU with engine data logging. Innovate wide band lambda sensor and processor (sensor not shown in photos but it will be included in sale). Magnecor KV85 competition plug leads. Large bore competition spec exhaust manifold and silencer (Dunnell Engines). Varley Red Top racing spec gel battery. Brise high performance starter motor. Set up at Jamsport rolling road, Northampton, 174 bhp at 6350 rpm (rev limit set at 7400 rpm), 152 lb ft at 4830 rpm Oil and filter just changed. Millers fully synthetic 5-40. Gearbox: Standard Type 9 5-speed, remote shift, electronic speedo. Performance: Weight - around 620kg. 0-60 - about 4.5s. There is a mass of information about this car on my website, link at the bottom of the post. I also have a huge history file of everything I've done. Here are a few photos: Link to comment Share on other sites More sharing options...
RedditchJay Posted April 27, 2011 Share Posted April 27, 2011 you taking it to the kit car show and putting a for sale board on it ? Link to comment Share on other sites More sharing options...
fatbaldbloke Posted April 28, 2011 Author Share Posted April 28, 2011 Monday if the weather's OK. Link to comment Share on other sites More sharing options...
RedditchJay Posted April 28, 2011 Share Posted April 28, 2011 also print off some ads and stick them in the cowsheds / telegraph posts etc etc ............ always see others doing it with information about which stand the car is on sale....... Link to comment Share on other sites More sharing options...
AidanPlace Posted April 29, 2011 Share Posted April 29, 2011 Good luck with the sale, I hope you're hanging about? Not sure what i'd do without the advice!! Aidan Link to comment Share on other sites More sharing options...
fatbaldbloke Posted April 29, 2011 Author Share Posted April 29, 2011 Too kind. No plans to move on from the WSCC, just looking for a new challenge within the Westie fraternity. I've done pretty much all I want to this one. Link to comment Share on other sites More sharing options...
fatbaldbloke Posted May 1, 2011 Author Share Posted May 1, 2011 Hoping to get up to Stoneleigh when doors open Monday morning. It should be in the WSCC For Sale area for most of the morning and early afternoon. Link to comment Share on other sites More sharing options...
RedditchJay Posted May 1, 2011 Share Posted May 1, 2011 only two cars in the sale area today.................thought there might be more............. Link to comment Share on other sites More sharing options...
RedditchJay Posted May 4, 2011 Share Posted May 4, 2011 cheap car for the money.................... Link to comment Share on other sites More sharing options...
fatbaldbloke Posted May 21, 2011 Author Share Posted May 21, 2011 SOLD into safe hands. Soon to be seen "oop north". Thanks for the interest those who contacted me. Apologies to David, pipped at the post. Now onto the next project, couple of options... Link to comment Share on other sites More sharing options...
Rab (bombero) Reid Posted May 21, 2011 Share Posted May 21, 2011 Congrats mate and remember to keep us posted with your new project .. .. and when you say oop north, how far up? Up here in Scotland perhaps, or is Watford, 'oop north' for you?! Link to comment Share on other sites More sharing options...
fatbaldbloke Posted May 21, 2011 Author Share Posted May 21, 2011 QUOTE keep us posted with your new project Certainly will, whatever it is I'm in the WSCC for the long haul. I've a few ideas but haven't really allowed myself to think too hard about it until this one was sold. QUOTE and when you say oop north, how far up? Lancashire I believe. Somewhere near the arctic circle anyway... Link to comment Share on other sites More sharing options...
AdamR Posted May 23, 2011 Share Posted May 23, 2011 Yes, that's right, in fact my neighbour is none other than a Mr. P. Olarbear! He claims to be Polish but I'm not convinced... I'm pretty close to Preston, so quite South really Thanks again for the viewing and drive out Ian, extremely enjoyable! Sunny weekend morning + superbly well put together car + another potential buyer coming along the next day (sorry David - glad you found another great car though, see other thread!) = easy decision for me. Any Lancs chaps - see you at the next meet! Link to comment Share on other sites More sharing options...
Onliest Smeg David Posted May 23, 2011 Share Posted May 23, 2011 No hard feelings Adam. We probably got it the right way around. Sounds like you were looking for a more track spec one and I was looking more road spec. Hopefully see you at a Lancs meet! Link to comment Share on other sites More sharing options...
Steve (stevel) Posted May 24, 2011 Share Posted May 24, 2011 2 more cars at the Lancashire meetings at this rate we will have extend the car park looks like you didn't need much to talk you into the Westfield clan Adam Link to comment Share on other sites More sharing options...
