lunny Posted June 27, 2003 Share Posted June 27, 2003 Im after a VDO sendor or alternative for use with the factory VDO electronic speedo. My propshafts just taken mine out and westfield want £50+ for a new one. Anyone know a cheaper supplier or alternative? that said, at least theres no risk of exceeding my 3000ml limit at the moment Martin Quote Link to comment Share on other sites More sharing options...
Richard M Green Posted June 27, 2003 Share Posted June 27, 2003 There is a device known as a 'Hunter Transducer' which connects into the gearbox at the normal mechanical speedo drive output and generates electrical pulses (2, 4 or 8 per revolution) to drive an electronic speedo. I bought mine from Merlin Motorsport, but no doubt other companies sell them. ISTR the cost is about £40. The product is described here: http://www.huntertransducers.com/hunter/ HTH regards Richard Quote Link to comment Share on other sites More sharing options...
AndyC_772 Posted June 27, 2003 Share Posted June 27, 2003 The Hunter should work fine - although be aware that the VDO speedo will work with a variety of different sensor types (electronic, magnetic or inductive), so you may need to connect the Hunter to different pins on the back of your speedo than the original sensor. I think I have the wiring diagram somewhere - email me if you need a copy. Quote Link to comment Share on other sites More sharing options...
lunny Posted June 27, 2003 Author Share Posted June 27, 2003 Looking at the hunter transducer it relys on connecting to a speedo cable exiting from the g.box. I dont have this. I have a MT75 box, which already has a electronic sensor fitted, ive just never connected it up - simply didnt think it would work. Does anyone know if this can be made to work with VDO electronic speedo's?. if it can problem solved. Cheers Martin Quote Link to comment Share on other sites More sharing options...
Enterpryse Posted June 27, 2003 Share Posted June 27, 2003 Does anyone know if the standard VDO gauges supplied by Westfield are just that - standard - in respect of the connectors on the back? Stuart Quote Link to comment Share on other sites More sharing options...
