amdaudi Posted June 23, 2003 Share Posted June 23, 2003 Can anyone please tell me the correct tyre pressure for 185 60's on a Westfield? Quote Link to comment Share on other sites More sharing options...
adhawkins Posted June 23, 2003 Share Posted June 23, 2003 I don't think there's a definitive answer really. 'About 18-20' would be my best recommendation (guess? ) Andy Quote Link to comment Share on other sites More sharing options...
amdaudi Posted June 23, 2003 Author Share Posted June 23, 2003 Thanks Andy that does explain quite a lot. Quote Link to comment Share on other sites More sharing options...
adhawkins Posted June 23, 2003 Share Posted June 23, 2003 How high were they? Andy Quote Link to comment Share on other sites More sharing options...
hogman Posted June 23, 2003 Share Posted June 23, 2003 Really depends on the weight of the car, for instance I ran my SE with Xflow at 17psi cold and now with an R1 run it at 15psi cold cos its alot lighter! I would start around 17 and go from there Cheers Kevin Quote Link to comment Share on other sites More sharing options...
amdaudi Posted June 23, 2003 Author Share Posted June 23, 2003 As high as 28psi! Please forgive me I am very new to this. Quote Link to comment Share on other sites More sharing options...
gadrego Posted June 24, 2003 Share Posted June 24, 2003 I run my XFLow with your tyre size at 18psi. Quote Link to comment Share on other sites More sharing options...
Toby Mack Posted June 24, 2003 Share Posted June 24, 2003 i have 17.5 all round in my xflow SE. 185.70 rather than 60 though. I've now worn a new set of tyres to about 4mm tread left in about 500 miles. The wear is even across the tread width so I guess that means the pressures must be pretty much spot on. Now all I have to do is work out how to make my tyres last a little longer fwiw I have found that a 1psi change can make a big difference to the feel at least so it is worth experimenting. Quote Link to comment Share on other sites More sharing options...
neilb Posted June 24, 2003 Share Posted June 24, 2003 Now all I have to do is work out how to make my tyres last a little longer Driving slower round corners, less hard braking, no doughnuts, etc.. Fun = Burnt rubber Quote Link to comment Share on other sites More sharing options...
Toby Mack Posted June 25, 2003 Share Posted June 25, 2003 Driving slower round corners, less hard braking, no doughnuts, etc.. ?? No, sorry..... I don't quite understand..... Quote Link to comment Share on other sites More sharing options...
neilwillis Posted June 26, 2003 Share Posted June 26, 2003 Do Westies actually go slow too then? Never seen that myself Quote Link to comment Share on other sites More sharing options...
adhawkins Posted June 26, 2003 Share Posted June 26, 2003 I was taking it easy in mine on the grass at Curborough last weekend. Andy Quote Link to comment Share on other sites More sharing options...
