newboy Posted May 16, 2003 Share Posted May 16, 2003 my 7.5 inch diff is in but i have had to put 2 washers on the left monting bolts and stud and 0 on the right so i can get 3mm clearence of the chassie at the dottom right of the diff (looking from the back of the car) after filing back the caseing. This seems to have left the drive shaft flange offset buy 5-6mm toward the driverside. I hope this all makes sence! will this be a problem? how could i put it right... Quote Link to comment Share on other sites More sharing options...
S8ight Posted May 16, 2003 Share Posted May 16, 2003 the shafts are different lengths. the outer casing on the lobro joint slides so you get quite a bit of movement there Quote Link to comment Share on other sites More sharing options...
newboy Posted May 17, 2003 Author Share Posted May 17, 2003 Soz, I ment the flange that points down the tunnel toward the gaerbox. its offset buy 5-6mm to the drivers side. Quote Link to comment Share on other sites More sharing options...
neilwillis Posted May 17, 2003 Share Posted May 17, 2003 It'll be just fine as it is. The prop shaft is able to deal with that kind of misalignment. Quote Link to comment Share on other sites More sharing options...
