wrightster Posted May 1, 2003 Share Posted May 1, 2003 a bit of a daft problem but on my spare wheel there is a metal valve/dust cap which i cannot remove i have tried pliers holding the valve itself whilst trying to unscrew the cap with another set of pliers !! i have also tried wd40 to release it - no luck , any ideas failing this if i take it to my local national tyres will they be a ble to replace the valve ? TIA Quote Link to comment Share on other sites More sharing options...
neilwillis Posted May 1, 2003 Share Posted May 1, 2003 Whenever I've taken my tintop to get tyres changed, they just cut off the valve to deflate em. One small point though, have you got those posh ali locking valve caps? I seem to recall they have a very small screw, which must be removed first. Have a look for a tiny aperture in the side of the cap, and see if there's a screw retaining the cap. HTH Quote Link to comment Share on other sites More sharing options...
Turbowestie.co.uk Posted May 1, 2003 Share Posted May 1, 2003 I seem to recall they have a very small screw, which must be removed first. Very good point, stops the little toads knicking them for there BMX's :/ Quote Link to comment Share on other sites More sharing options...
neilwillis Posted May 1, 2003 Share Posted May 1, 2003 At £20 a set, you'd need a little security that's for sure! I'm still skint after my build, so mine is going to have the PVC ones (Plastic Very Cheap)!!! Quote Link to comment Share on other sites More sharing options...
Megablade Paul Posted May 2, 2003 Share Posted May 2, 2003 £9.99 from Westfield with the logo on, Wrightster if it's got em, I've got the little thingy for unscrewing them. BE CAREFUL though boys they're seriously HEAVY Quote Link to comment Share on other sites More sharing options...
neilwillis Posted May 3, 2003 Share Posted May 3, 2003 I suppose they have to be to keep the air in!!! Quote Link to comment Share on other sites More sharing options...
wrightster Posted May 3, 2003 Author Share Posted May 3, 2003 nope it aint got a little screw on and it aint got a logo on but it is stuck !! Quote Link to comment Share on other sites More sharing options...
Phssthpok Posted May 3, 2003 Share Posted May 3, 2003 .....warm the cap up with a quick (careful) blast with a blowlamp, then try undoing. Quote Link to comment Share on other sites More sharing options...
S8ight Posted May 3, 2003 Share Posted May 3, 2003 try to get hold of a set of Snap On linemans pliers. theyll grip anything. i got a crossthreaded disc bolt out with a set years ago ! Quote Link to comment Share on other sites More sharing options...
Megablade Paul Posted May 3, 2003 Share Posted May 3, 2003 Wrightster, me and Nanaman were wondering whether you may have been regretting letting Nic and Robbie go? Quote Link to comment Share on other sites More sharing options...
