Phoenix Posted January 2, 2011 Share Posted January 2, 2011 As above. Am interested in a pair of the CarbonMods indicator pods but would like to see what they look fitted like before shelling out! Quote Link to comment Share on other sites More sharing options...
TIG Brother Posted January 2, 2011 Share Posted January 2, 2011 the ones that sit under the headlights? catering van style? im fitting mine tomorrow, will be able to post a picture then Quote Link to comment Share on other sites More sharing options...
Phoenix Posted January 3, 2011 Author Share Posted January 3, 2011 Yes, think so , would really like to see how they are fitted. Cheers Quote Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted January 3, 2011 Share Posted January 3, 2011 They look virtually the same as the Fluke Carbon ones. pics here Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 3, 2011 Share Posted January 3, 2011 Yep, same as Caterhams. I have them (Caterham ones) on my car over there... <<<<<<<<< Easily the nicest way to mount the indicators IMHO... Quote Link to comment Share on other sites More sharing options...
Phoenix Posted January 3, 2011 Author Share Posted January 3, 2011 Thanks, do these fit onto standard WF headlight brackets or do they need the caterham brackets? Quote Link to comment Share on other sites More sharing options...
adam123 Posted January 3, 2011 Share Posted January 3, 2011 QUOTE Thanks, do these fit onto standard WF headlight brackets or do they need the caterham brackets? yes, will fit the wf brackets no problem. Quote Link to comment Share on other sites More sharing options...
westy turbo Posted January 3, 2011 Share Posted January 3, 2011 then which indicators u use? Quote Link to comment Share on other sites More sharing options...
chazpowerslide Posted January 3, 2011 Share Posted January 3, 2011 I have the Caterham ones on mine. Agreed with Blatters, they look good and you don't have to p**s about with the wiring each time you take the nosecone off as you would if you had the WF ones mounted on the nosecone. Chaz. Quote Link to comment Share on other sites More sharing options...
Doug Dastardly Posted January 3, 2011 Share Posted January 3, 2011 Anyone know if they're IVA compliant? I'm guessing that if they're fitted to caterhams they must be? Doug Quote Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted January 3, 2011 Share Posted January 3, 2011 Anyone know if they're IVA compliant? I'm guessing that if they're fitted to caterhams they must be? Doug On a Caterham, maybe. But... For IVA you'd need to ensure they meet the angle of visiblity requirements which is determined by a number of factors. The height of the headlamp brackets, their position relative to the front of the nose cone, Front track width and the cycle wings are all different on a Westfield to a Caterham so could influence whether they comply or not. Quote Link to comment Share on other sites More sharing options...
adam123 Posted January 3, 2011 Share Posted January 3, 2011 QUOTE Anyone know if they're IVA compliant no, they wont pass sva with them. not sure about iva but guessing it will be the same. Quote Link to comment Share on other sites More sharing options...
Doug Dastardly Posted January 3, 2011 Share Posted January 3, 2011 Thanks for the replys. That's a bit of a shame, because I liked the look of them. I think that I'd rather stick with the WF ones than have holes in my nose, on the whole. Doug Quote Link to comment Share on other sites More sharing options...
westy turbo Posted January 3, 2011 Share Posted January 3, 2011 any ideas where to get the actual indicators? Quote Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted January 3, 2011 Share Posted January 3, 2011 any ideas where to get the actual indicators? Standard Westfield Indicators are IIRC from Landrover Defender and probably a lot of earlier BL cars. Quote Link to comment Share on other sites More sharing options...
