duncansaunders Posted March 23, 2003 Share Posted March 23, 2003 Bought a Polo Radiator yesterday. Marked as being suitable for 1050 from 83 - 91. Looks nice and light but both hose connections are on the left hand side and there is also an air bleed fitting. Have I got the right one or is there one that has the hose connections on different ends - so it will fit easily with the hoses I have. Cheers Duncan Making progress. Quote Link to comment Share on other sites More sharing options...
Blatman Posted March 23, 2003 Share Posted March 23, 2003 Sounds like right one to me...... Of course, both fittings could be on the right hand side, as well........... Quote Link to comment Share on other sites More sharing options...
furtive Posted March 23, 2003 Share Posted March 23, 2003 Does it look a bit like this? If so, it's the right one. Quote Link to comment Share on other sites More sharing options...
duncansaunders Posted March 23, 2003 Author Share Posted March 23, 2003 The very same! Thanks guys Duncan Quote Link to comment Share on other sites More sharing options...
Neil Purdie Posted March 27, 2003 Share Posted March 27, 2003 There are many ways of mounting the rad, but.... To get the radiator as far forwards in the nose cone without foulling. Allign the mounting bosses with the top chassis rail ( see Fast Westies pic, note he has used the front mounting bosses ) , ensure the gap between the rear top bosses and chassis is no more than 150mm, with the rad hanging vertically. Hope this may save you the trial and error I have just been having Neil Quote Link to comment Share on other sites More sharing options...
duncansaunders Posted March 27, 2003 Author Share Posted March 27, 2003 Thanks for the info. One question though - does your radiator have an air bleed fitting at the top left hand corner next to the top hose connection? Mine does but the one in fastwesties picture does not seem to? Cheers Duncan Quote Link to comment Share on other sites More sharing options...
steve wilson Posted March 27, 2003 Share Posted March 27, 2003 Mines out of the corrado ( just bigger) but the same as the polo and has the bleed. Quote Link to comment Share on other sites More sharing options...
steppenwolf Posted March 27, 2003 Share Posted March 27, 2003 It is standard to have this tiny air bleed outlet ( from memory it is 5 or 6mm ). The normal procedure is to blank it off with a stainless steel bolt coated in silicone sealant and screwed into the outlet. Quote Link to comment Share on other sites More sharing options...
duncansaunders Posted March 27, 2003 Author Share Posted March 27, 2003 CORRADO RADIATOR? I have a VR6 Corrado and the radiator is massive - I doubt it would fit in the engine bay of my Westfield lengthways let alone sideways within the nose cone. Still, plenty of cooling capacity to keep my 2.9l in check Quote Link to comment Share on other sites More sharing options...
