adamnreeves Posted October 24, 2010 Share Posted October 24, 2010 Item installed on the car but never used as I have the racetech dash2 which uses a different transducer. £30 pus P&P or collection. Link to comment Share on other sites More sharing options...
matt_c Posted October 25, 2010 Share Posted October 25, 2010 Item installed on the car but never used as I have the racetech dash2 which uses a different transducer. £30 pus P&P or collection. Is this the one for the VDO gauges (The one that mounts above the diff)? Link to comment Share on other sites More sharing options...
adamnreeves Posted October 25, 2010 Author Share Posted October 25, 2010 Item installed on the car but never used as I have the racetech dash2 which uses a different transducer. £30 pus P&P or collection. Is this the one for the VDO gauges (The one that mounts above the diff)? Yes its the large one that has a mount welded in the chassis tube looking down on the bolts of the CVJ diff side. Link to comment Share on other sites More sharing options...
matt_c Posted October 25, 2010 Share Posted October 25, 2010 Item installed on the car but never used as I have the racetech dash2 which uses a different transducer. £30 pus P&P or collection. Is this the one for the VDO gauges (The one that mounts above the diff)? Yes its the large one that has a mount welded in the chassis tube looking down on the bolts of the CVJ diff side. Sorry, I want one for smiths gauges, the type that mounts to the front upright. Thanks anyway Matt Link to comment Share on other sites More sharing options...
adamnreeves Posted October 25, 2010 Author Share Posted October 25, 2010 Item installed on the car but never used as I have the racetech dash2 which uses a different transducer. £30 pus P&P or collection. Is this the one for the VDO gauges (The one that mounts above the diff)? Yes its the large one that has a mount welded in the chassis tube looking down on the bolts of the CVJ diff side. Sorry, I want one for smiths gauges, the type that mounts to the front upright. Thanks anyway Matt Did you forget what gauges you bought Link to comment Share on other sites More sharing options...
matt_c Posted October 25, 2010 Share Posted October 25, 2010 Item installed on the car but never used as I have the racetech dash2 which uses a different transducer. £30 pus P&P or collection. Is this the one for the VDO gauges (The one that mounts above the diff)? Yes its the large one that has a mount welded in the chassis tube looking down on the bolts of the CVJ diff side. Sorry, I want one for smiths gauges, the type that mounts to the front upright. Thanks anyway Matt Did you forget what gauges you bought Umm,,, no I had a feeling it would be for the VDO gauges (as they appear to be more popular than the Smiths ones) but thought I'd check with you on the off off chance. Link to comment Share on other sites More sharing options...
adamnreeves Posted October 25, 2010 Author Share Posted October 25, 2010 Oh right, checking for the negative rather than the positive. Glass half empty of half full. Link to comment Share on other sites More sharing options...
