Lurksalot Posted October 3, 2010 Posted October 3, 2010 I guess that's what happens when you try to extrude a non Newtonian dilatant fluid Quote
Gromit Posted October 3, 2010 Posted October 3, 2010 Most of the problems people have with the mortar guns is that they dont use them properly. You have to make sure once its loaded to tighten the nut at the top of the shaft so it squashers the rubber seal out against the tube. If you dont do this the water in the mix will squeeze past the seal and you`ll end up locking the gun after the plungers gone down a couple of inches. And as someone has already said, not ALL builders are uneducated yobs, there are a few of us with some brains. Quote
slater Posted October 4, 2010 Posted October 4, 2010 There is a mortar gun on the market that uses a special mix of cement, b****y expensive though and the mortar has to be machine mixed. Only cost effective though if you have over 500 square metres to do, better off with a hand hawk, decent pointing trowel and some decent music. lewis Quote
barney Posted October 4, 2010 Posted October 4, 2010 QUOTE and some decent music. thats were Peter might dip out.. Quote
Asterix Posted October 4, 2010 Author Posted October 4, 2010 and some decent music. thats were Peter might dip out.. ...cheeky beggar, I'll have you know that there's nothing wrong with a bit of arapaho indian chants compilation Quote
steve_m Posted October 4, 2010 Posted October 4, 2010 Bought a 600w cheapo B&Q grinder Will it rev high enough ? Quote
housebeautician Posted October 5, 2010 Posted October 5, 2010 I'm not a builder What a surprise! Quote
