Guest Posted January 20, 2003 Posted January 20, 2003 Hello, I'm fitting the bodywork but still haven't got the rollover bar (I am going to get the Westfield bar) The problem is that there are 3 holes in the metal chassis mounting and I understand that the bar only has one bolt. Question is: which hole do I drill through? Or, do I actually have to drill a new hole through the metal plate? Thanks, - Dan. Quote
hilux Posted January 20, 2003 Posted January 20, 2003 westfield bar = 1 bolt Rac bar = 3 bolts Wait until the bar arrives Hilux Quote
Mark Stanton Posted January 20, 2003 Posted January 20, 2003 Don't drill until you have your bar in your hands Don't even borrow someone elses Whatever spec bar you go for Quote
steppenwolf Posted January 20, 2003 Posted January 20, 2003 If you are getting the standard Westfield bar, it uses NONE of the holes already punched in the mounting plate - you have to drill your own 13mm hole to match the bar. As Mark says, it would be more than prudent to wait for your own bar to arrive before drilling as you really do need to get these two holes perfectly right first time! Quote
Guest Posted January 21, 2003 Posted January 21, 2003 Thanks all, I suspected this might be the case after seeing the Cortina uprights/cycle wing brackets duo - Dan. Quote
