Just a few comments.
Its a waste of time and money buying an engine, any engine then taking it apart to fit aftermarket rods, cams, clylinder heads polished and ported and various other bits and pieces.
The games moved on from those  days.
Pick the right engine, fit the obligatory throttle bodies and a dry sump if necessary then its a JD :)
If it goes bang, remove the bits on the outside and buy  another .
Needless to say the three I have in mind  are all Hondas
Standard Zetecs ,Duratecs , Vauxhalls are so last year!
Now let the fur fly :D
Sounds like fighting talk. So if someone was sitting there with a 2L zetec on carbs or tbs how easy and what engine would you go to?
K20A - Speak to Troy at NMS - he know's how easy it is. :D  :p  :p
Tubs
  • Replies 96
  • rose5691
    10
  • thos
    6
  • Tubs
    6
  • dombanks
    5
Naaaaaaahhhhhhhh...................there was a Honda Engine in a Westfield long before a Duratec or Sigma..........its so year 2000  :p
2000 how time flys.
What a cracking car it could have been if you had fitted  a differant gearbox and continued its development. ;)
Regards.
Got to be the s2000 honda, no comparison, Fords don't even get a look in.
what about the gearbox? i thought some of the thinking of the ford engines was that the type 9 just fits on easy
Bellhousings available for both Honda K20 and F20 engines to Type9 pattern box ie; quaife / elite.
Mick has carbon for the F20, and DMRR do kits for both F20 & K20.
The K20A is much more upgradeable than the F20C and cheaper. :cool:
Tubs
Tubs
I think you're missing the point Mick is making. The joy of either engine should be fit and forget!!
I'm fitting an F20C for that exact reason - 250bhp from bolt on bits, I hope to never had the head off or go buying pistons/rods/cams etc!
Tubs
Noooooooooooo - how can you not plan upgrades to your engine? :p  :D
Tubs
Tubs
Tubs .the k20 maybe cheaper , but please tell me how its more upgradeable.
And how you achieve it?
Mostly because there are a wider range of parts available and those parts tend to be cheaper.
Because of the relative rarerity of the F20C and the more limited gains available there is a lot less demand for parts and those who are looking tend to be wealthier in the first place.
Remember that the K20A is used in the Honda Civic Type R and the ITR both of which have a wider following than the S2000 and also, because the engine has a lower starting point there is more to be gained by upgrading. You might say that there is no need to upgrade the F20. However, if you start with 200ponies then an upgrade that will give you 60 more ponies is worth having - by contract the same end power would mean only a 20pony gain for the F20 which reduces the financial benefit.
A quick look at a web site such as Skunk2 will show an abundance of tuning parts for the K but only one or two (one of which is FI) for the F.
There is also scope for the to enlarge the capacity of a K20A. Sticking a 2.4 block onto the K20A head is a very cheap power upgrade which, with a few other mods, per the DMMR web-site, will give you 326bhp. :devil:
Tubs
Tubs
So what have you got, a collection of Skunk 2 goodies or a 326 bhp dmmr K2.4 in your Westfield?
:D
I'm waiting to see what I've got now before I make any plans. One :D  thing for sure, I don't think I'll be going for the 326 motor!
Tubs
stroke the 2.4 to 2.6 and get 400hp N/A :)
Instead of debating upgrades to engine that doesn't need them, get on with putting said engine in car!!!
IMHO if you think you need to upgrade an F20 engine, you must be competing with the car on slicks. I drive Micks car and manage to acheive greater top speeds at some events (the fast ones like Aintree) than those running slicks. This tells me that the car doesn't lack horsepower, and therefore doesn't need upgrades.
Now get in the garage and bring out a car to beat Micks!!
