Hello there...
Build manual lists a coopers type oil filter for the 2.0L Zetec, I my local Halfords they only stock their own make and Champion, does anyone know a matching part number for these.
TIA
JD  ???
The Halfords part number is HOF238 (Renault 4) They seem to have stoped stocking them now though. Try your local motor factors for a - Renault 4 filter with the spring inside.
Dave O.
Is this the really shallow one. AndyH bought an 1800 Zetec westy at the weekend and that has a 'really' shallow oil filter
On my 1800 Zetec, I used to use a Crosland 659 ( six five nine ) compatible (quite a shallow unit) but I then bought some Valvoline Oil from Raceline and they also supplied a Crosland 573 Compatible filter which is 'full size' and to my surprise it fitted despite the steering column shaft.
Several oil changes later, I wanted to buy another filter from Raceline but their manufacturer had stopped making the type that Raceline like but they now recommend a Unipart GFE 166 which should be readily available - this again, however, is a 'full size' ( 9cm ) one so check your clearance first.
i know that the long one won't fit on the later Zetec R engine, like ive got the short one is only an inch from the steering shaft as it is,filter screws to block face not alloy housing as well. :0
I think the 2 litre engine has a subtle difference in the angle of the oil filter plate, meaning it needs a smaller filter than the 1800.
Or maybe it's a Mondeo / Escort difference.
Kevin
