Throttle bodies
I'm not one for covering up mistakes, but I definitely don't want to put words in to your mouth, so to speak.
If you're happy to let it stand, so am I........
We're being awfully sensible and serious aren't we ??!!  :D  :D
Bet my car's quicker than yours mister  :p  :devil:  :D
Is that the sound of a gauntlet being thrown down.............. :0  :0
Mind you, it'd be a laugh. Shame your car's only doing about 20knots max right now.......I can run faster than that.......
just.......
in short bursts................
very short bursts.............
:zzz:  :zzz:  :zzz:  :D  :D  :D
*thud*
Yep, if you like !!  :D
Just to make the test totally fair and comparable, I'll use a drag strip over here and you can use on in the UK.  I mean, one drag strip's the same as any other isn't it ??!!  :D  :D
Heh! Bet Gee_Fins R1 powered beasty will be quicker than both of them!
Cheers,
Al.
Not when he's added the required amount on ballast for the class it will be running in.....
I`m no expert :blush: however I consider that throttle bodies and injection should IMHO offer some power advantages particularly in mid range :durr:
Carbs are ok at idle and at full revs but are always a compromise at part throttle.
Therefore I would assume that injection and throttle bodies would improve consumption only in the mid range and due to accurate metering of fuel/air ratios must improve power again particularly in mid range.
As I said, I`m no expert :arse:
  • 2 weeks later...
:t-up: I fit the SBD 208 kit this year after running twin 45's for the last 3 years on my Vx 2.0 16v
On carbs peak power was just over 180bhp but it kept going out of tune quite quickly, with the throttle bodies after a good setting up session it produced 207bhp and it's so much more drivable and torquey also at higher revs it seems much smoother and free' er revving.
after 7 months it seems just as powerful as when it was first set up
