brindle Posted June 24, 2010 Posted June 24, 2010 Hi, Do any MX5 SDV builders have the plastic section between the fuel injection system and the air filter (that would run around the front of the engine originally? I need a repalcement part for a lovely Mk1 MX5 and I'm hoping someone on here has one knocking around?!?!? Cash / beer tokens waiting!! Cheers.
Mark (smokey mow) Posted June 25, 2010 Posted June 25, 2010 I have one but it's been butchered pretty badly with a hacksaw from where it was on the westfield and it's missing a couple of bits so probably not much use to you. They're cheep as chips on the bay though
brindle Posted June 28, 2010 Author Posted June 28, 2010 I have one but it's been butchered pretty badly with a hacksaw from where it was on the westfield and it's missing a couple of bits so probably not much use to you. They're cheep as chips on the bay though Cheers, Its the 1.8 - and looks different to that. just though that if someone was in the process of stripping a car they might want a few squid for one instead of scrapping it. Cheers
Mark (smokey mow) Posted June 28, 2010 Posted June 28, 2010 Its the 1.8 - and looks different to that. just though that if someone was in the process of stripping a car they might want a few squid for one instead of scrapping it. Cheers The SDV kits use that pipe if you build it to the westfield Manual, however you may be lucky if somebody has upgraded from the standard airbox to a cone filter. Failing that I normally use MX5 Heaven for secondhand stuff
brindle Posted June 28, 2010 Author Posted June 28, 2010 Its the 1.8 - and looks different to that. just though that if someone was in the process of stripping a car they might want a few squid for one instead of scrapping it. Cheers The SDV kits use that pipe if you build it to the westfield Manual, however you may be lucky if somebody has upgraded from the standard airbox to a cone filter. Failing that I normally use MX5 Heaven for secondhand stuff Ahh b****r. thanks for the heads up - I'll look on there. Cheers.
