gregh Posted November 8, 2002 Posted November 8, 2002 I ordered some bonnet grommets from Westfield, which I expected to go in the nose cone where the 2 'spikes' from the bonnet push in. I received two rubber grommets that look more like caps, they have no hole in them and they also seem thin to me. Is this expected, or should I have some with holes already in? thanks, Greg Quote
Mark Stanton Posted November 8, 2002 Posted November 8, 2002 Those rubber cap looking things - sound like rubber caps rather than grommets Where's Wallace he'll know. Have a speak with Westfield and explain what your requirements are i.e. Rubber grommets with holes for where the bonnet pins sit in the nosecone Other than that your local Halfrauds always carries a selection of rubber grommets (and caps) where you can see before purchase Quote
gregh Posted November 8, 2002 Author Posted November 8, 2002 >> Have a speak with Westfield and explain what your >> requirements are i.e. Rubber grommets with holes for >> where the bonnet pins sit in the nosecone Having spoken to Westfield twice to explain my needs over the past 2 months, I am a little disappointed by what has turned up and the time taken, hence my question just in case I'd got what I asked for!! Regards, greg Quote
steppenwolf Posted November 9, 2002 Posted November 9, 2002 You should have received two proper rubber grommets 24mm o/s diameter, 12mm i/s diameter and 8mm thick. How do I know this? I have just ordered and received the correct ones! Ask for 'two grommets for the front bonnet pins' Quote
