Rear suspension fitting?
Have had to dismantle my rear suspension as the wheel bearing decided to fall apart when I inserted the outer hub.
On reassembly I followed the build manual, but noted that on the bottom wishbone fixing to the upright (NOT the rose joint side), there was no mention of a washer between the upright and the bottom wishbone arm. Is this the case...does the upright mate right against the edge of the bush without a washer? If someone could remember how they set their's up I would be most grateful for the info.
Regards,
JD
I have a washer between the upright and the wishbone. This should be there to stop the wishbone 'eating away' at the aluminium casting of the upright!
as I thought should be the case...
cheers steve
