Hi all,
I'm starting to put together a winter project of converting my pinto to a silvertop zetec engine, has anyone got any of the following surplus to requirments?
Exhaust manifold
Megajolt system
cooling systems parts (metal hoses etc)
And a wild shot of a complete 1.8 silvertop zetec engine?? :bangshead:
Mark
hello mark why dont you go duratech as the exhaust is on the same side as the pinto
there was a guy on locost builders selling one
ps do you want the pressure sender back
cheers
dave
or Zetec SE Complete kit here  And the exhaust is on the right side and you save weight = win/win  :t-up:
  • 1 month later...
Still looking for parts for my conversion, any zetec parts considered ;)
  • 3 weeks later...
yes it has a clutch, no alternator as its electronic egnition, no starter, water pump is built in, gearbox has been rebuilt, the shaft has been turned to fit zetec engine.
Since when does electronic ignition determine that an alternator isn't needed and why is a different sump needed for weber / TB's ?
And why has the type 9 been machined to fit the engine? It fits anyway!!  :bangshead:
Agreed, its a poor listing, by someone who really doesn't know whats going on....
I have a standard low mileage 2ltr and a high spec 220bhp zetec silvertop for sale if you're interested?
pm me or email me at mbaileywscc-ao@hotmail.co.uk if you're interested.
I will be advertising the high spec engine on here probably tomorrow & it'll be on pistonheads aswell.
I bought the standard engine for a mates mk2 escort but by the time I got it he'd already found another one, the heads are off both engines for inspection btw.
Cheers,
Mark.
Hi Mark,
Thanks for the offer of the 2.0 zetec, ideally I would like a 1.8 silvertop zetec, thanks again :) Mark
I'm still looking for complete 1.8 zetec silvertop if anyone is upgrading to a 2.0 zetec or duratec also does anyone have any parts for sale i.e cooling systems hoses (metal or rubber)etc
Mark
Hi MCB,
Ok let me explain Mark B has just contacted me as im very close to making a decision on his engine and in which case I would be replacing a 1.8 series 1 silvertop. Its running perfectly. Would this be of any use. Its running at 155bhp. When would you need it for?? This might help me to make my decision to buy his as would help massively to offset the cost.
Regards
Greg
  • 2 weeks later...
Hi there, I'm converting to modified 2.0 Zetec so my factory 155bhp (130 cams) 1.8 is going to be available, quite possibly with inlet manifold, 40mm jenveys and suited injectors on it. It runs perfect, done 10k miles and serviced every year (1000 miles). Need to figure out price....Is this of any interest to you?
Adrian.
Mark, surely you going the wrong way man! Should be Zetec > Pinto conversion! :bangshead:
Don’t do the down grade! :p  :D  :laugh:
Hi
I have a Westfield supplied stainless mainfold and collector if you still need one?
