peterpeter Posted August 25, 2002 Posted August 25, 2002 Got my westy yesterday ...yellow 1998 160bhp pinto SEIW GOrgoeus!!! Needs a few items sorting out, some mechanical, some cosmetic/external, Is there anyone in the southeast (KENT ETC) you would recommend??? Help much appreciated... Quote
Stueyboy Posted August 25, 2002 Posted August 25, 2002 The one I know is Terry Nightingale but he is in Newmarket which I suppose it too far North for you. Quote
neo Posted August 25, 2002 Posted August 25, 2002 welcome to westy ownership you wont regret it i havent,but now its time to change your thinking,westys are hands on cars and require constant tweeking and fidling with all be it minor or major,its time to get the tools out and take the plunge and start the repairs yourself you will enyoy and in the process save some dosh and then spend the saving on more westy bits, theres always plenty of help on here if you get stuck Quote
Stueyboy Posted August 25, 2002 Posted August 25, 2002 ...and remember, always measure it again before you saw into it, cut it off or put a rivet through it (ooh matron! Quote
jamie Posted August 26, 2002 Posted August 26, 2002 Needs a few items sorting out, some mechanical, some cosmetic/external, Is there anyone in the southeast (KENT ETC) you would recommend??? peter what sort of help are you looking for ? iam in sittingbourne and know a few garages/paint shops and engine tune people but not many westy owners but i have good insight of the little cars jamie Quote
peterpeter Posted August 26, 2002 Author Posted August 26, 2002 Thanks for replying to my message, The car needs a few minor cosmetic jobs (nose cone filler/respray) etc, And one or two mechanical jobs, a) blowing exhaust joint, b) split rubber gait on ball joint (possible ball joint replacement also) c)coolant needing full flushing and replacemnt. d)possible speedo repair If you have any phone numbers or addresses, I would be very grateful Tif (peterpeter) Quote
westy Posted August 26, 2002 Posted August 26, 2002 a) blowing exhaust joint, Which bit? d)possible speedo repair What is the symptoms? Quote
peterpeter Posted August 27, 2002 Author Posted August 27, 2002 a)the exhaust is blowing just at the joint where the 4 pipes go into one under the stainles steel heat guard. Its actually at the 4 joint junction. The seller reckoned it shouldnt be welded because the exhaust needs to move a little. The vehicle inspector felt it should be welded to improve nse and flow. b)The speedo reads fine upto 55mph after which it hovers around 60 and then starts to go backwards!!! ANy help much appreciated. Quote
Bob Green Posted August 27, 2002 Posted August 27, 2002 Congratulations on owning your first decent car! Somewhere in the threads I mentioned I leave the clamp off where the silencer meets the collector box. This stops the front silencer weld from cracking and on my car, a 2 Ltr Pinto, doesn't blow. Secondly, have you an electric speedo? If so the clearance between the sensor and closest prop yoke should not be more than 2mm or else the speedo will read slow and irratic. Before setting up, make sure the Gearbox mounting is in good order as too much movement will allow the prop yoke to clout the sensor. Forget paying someone to repair the car, you will find all the help you need on this website Quote
jezmilligan Posted September 12, 2002 Posted September 12, 2002 Is that the Tif I met at Bassingbourne some time ago? If you do find a Westfield specialist in SE please let me know -I'm in Greenwich & I'm having to travel up to Terry Nightingales to have him look at a few things and it's quite a treck. Are you going to Bedford on 28th? Jez. Quote
paulleo 72 Posted September 12, 2002 Posted September 12, 2002 Tif where about's are you in the south east anywhere near Eastbourne Quote
peterpeter Posted September 15, 2002 Author Posted September 15, 2002 Yes Jeremy ,, its me from Bassingbourne!!! Reg and I are going on the 28th to the RMA day... hopefully we will see you there and catch up... Ive found a local chap who race preps c******ms in Horton Kirby...( near BRANDS HATCH) .. hes a bl**** nice bloke but hes quite busy. Hes sorting some of out minor gripes and doing some upgrades for us in oct. Paulleo/..... I live in Swanley Village in Kent ( Again .. near Brands) Quote
Fast Westie Posted September 16, 2002 Posted September 16, 2002 Peter I'm down near Wingham if you need a hand. I pop up to Sidcup to see my folks sometimes. BTW, I'm racing at Lydden on the 28th Sept in this -> SEMSEC Quote
Phil W Posted September 16, 2002 Posted September 16, 2002 Peter, Just to add to the general comments- although I have only been a Westy owner for a year (built my 1800 Zetec SEIW May 2001 ) - half the fun is being able to do things yourself instead of using rip off garages p.s I live in Welling just down the road from you Quote
peterpeter Posted September 16, 2002 Author Posted September 16, 2002 where is wingham??? Do you guys go to the local meets at essex/ surrey??? Are any of you going to these track days (I booked on) -- 28th sept..bedford.. --12th Oct. Goodwood --21st oct Brands( ill be there afternoon (reg..my neighbour and co-car owner will be there all day) --november (bookatrack cant remenber when) 21st Dec goodwood (easytrack) if so drop me a mail... Quote
