CedricTheBrave Posted February 21, 2010 Share Posted February 21, 2010 In the Zetec kit there is a straight length of 32mm alloy tube with a 15mm outlet welded about 3 inches from the end. does anyone have one knocking around or something similar? Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted February 22, 2010 Share Posted February 22, 2010 Will have a look in my clutter. Might have something which will suit your requirements Link to comment Share on other sites More sharing options...
thos Posted February 22, 2010 Share Posted February 22, 2010 CBS will do something for you: http://www.cbsonline.co.uk/32mm-un....8-p.asp http://www.cbsonline.co.uk/univers....6-p.asp Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted February 22, 2010 Share Posted February 22, 2010 CBS will do something for you: http://www.cbsonline.co.uk/32mm-un....8-p.asp http://www.cbsonline.co.uk/univers....6-p.asp Or even better they do there Link to comment Share on other sites More sharing options...
thos Posted February 22, 2010 Share Posted February 22, 2010 Mines cheaper Link to comment Share on other sites More sharing options...
Mark (smokey mow) Posted February 22, 2010 Share Posted February 22, 2010 Mines cheaper mines more shiny Link to comment Share on other sites More sharing options...
CedricTheBrave Posted February 22, 2010 Author Share Posted February 22, 2010 Yeah saw those thanks wanted one about 15 or 16 inches long like the Westfield one, I could get either of those from cbs but i would have to have another joint etc to get the length which makes it untidy and more expensive. Westfield will supply the Zetec one for about 20 quid but its only 14.5 inches which is tight but may be ok so I may go that route in the end. thanks for the replies tho Link to comment Share on other sites More sharing options...
thos Posted February 22, 2010 Share Posted February 22, 2010 Other option is a length of silicone hose, with a self-sealing take off: http://www.demon-tweeks.co.uk/product....LOSST01 Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted February 22, 2010 Share Posted February 22, 2010 Other option is a length of silicone hose, with a self-sealing take off: http://www.demon-tweeks.co.uk/product....LOSST01 Been there, tried that, it didn't; (self seal, that is) Link to comment Share on other sites More sharing options...
thos Posted February 22, 2010 Share Posted February 22, 2010 I've used them for an 8mm take off on a 32mm hose, found a small weep initially, but not since. That saying, I wouldnt like to try a 16mm take off on 32mm hose, as it seem to flatten off the hose too much. Pricey little b*******s too!! Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted February 22, 2010 Share Posted February 22, 2010 Sorry - some ludite has molested mine rendering it u/s Link to comment Share on other sites More sharing options...
mark.anson Posted February 22, 2010 Share Posted February 22, 2010 Ring Bryn at Allyfab. He will make you one to your own design. Link to comment Share on other sites More sharing options...
geothro Posted February 23, 2010 Share Posted February 23, 2010 CBS also do a stepped plastic tee 32mm to 15mm you would have to cut off the 28mm and 12mm parts very cheap Link to comment Share on other sites More sharing options...
