daveblissett Posted February 10, 2010 Share Posted February 10, 2010 i am after a 0-5 bar VDO oil presure sender 1/8 npt thread The one with two conections one for idiot light and the other for the gauge what have you got?? cheers dave Link to comment Share on other sites More sharing options...
Hammy Posted February 11, 2010 Share Posted February 11, 2010 I've a 0-5 bar 1/4" npt with only the one connection only out of my x/flow, but i also have teee piece that goes with it and has a fitted pressure switch Close but no cigar I guess ? what you want (and i've just bought) can be had for about £45 new Link to comment Share on other sites More sharing options...
daveblissett Posted February 11, 2010 Author Share Posted February 11, 2010 thanks hammy but i want a two pole one to keep it nice and neat where did you get one from for £45 cheers dave Link to comment Share on other sites More sharing options...
MCB Posted February 11, 2010 Share Posted February 11, 2010 Hi, I've got one going spare, how do I tell what size thread it is? Mark Link to comment Share on other sites More sharing options...
Hammy Posted February 11, 2010 Share Posted February 11, 2010 MCB there is a code on the side of it and you can look up the spec from that, or if you post wot cars its off several people will tell you the size, someone will say you're an idiot and one might be right Got mine from www.partsforaircraft.co.uk ( put VDO in the search window) It arrived in two days. £45 was from memory the receipt sez: 360-009 0-5bar sender 1/8th NPT (£35.54 +vat) and shipping (£1.75), also bought 1/8 to 14mm adpater from the same place to fit my XE. ( sender has the two connections as you wanted and is new in VDO packaging with instructions). ..just hope it fits ! *edit* -yes fits! Link to comment Share on other sites More sharing options...
