neilb Posted August 19, 2002 Posted August 19, 2002 I was just wondering at what point an aeroscreen stops being an aeroscreen and turns into a windscreen and you have to fit wipers, heaters etc.. Is it a simple case of you look over an aeroscreen and through a windscreen or is there a more technical definition? Thanks Neil Quote
Richard M Green Posted August 20, 2002 Posted August 20, 2002 The definition which you seek is contained within the SVA Manual available from the Vehicle Inspectorate. Basically it defines a vertical limit above the seat base cushion. Anything that intrudes into the driver's FoV above that limit is considered to be a windscreen, and as such requires wipers, washers and a means of de-misting. HTH Regards all Richard Quote
Tomcat Posted August 20, 2002 Posted August 20, 2002 My car has already gone through SVA without a windscreen so when I fitted a screen I didn't bother with a demist as it isnt part of the MOT, I did check with my local testing station, it will fail SVA but isn't part of the MOT. It saved the hassle of plunbing one in. I did have to have the wipers though, even though they dont in reallity actually "wipe" the screen, they more "smear" it!! Quote
Westfieldman Posted August 20, 2002 Posted August 20, 2002 My aero screen is 2mm short of being a windscreen from the passengers seat but of from the drivers side look at the picks on my web site link below the seats are at different hights so a pass was granted. Paul. Quote
