Brake Calipers
mark.anson
I want some decent brake calipers to replace the Hi Specs.
Would like APs or Alcons but would consider Wilwood Dynalite, or similar caliper that takes the Dynalite pad.
What you got!
Edited: Must fit under 13"rim and fit Westfield alloy upright and solid disc
Link to comment
Hi Mark
have you looked HERE :t-up:
Tony
Mmm they look the same as the Bremsports I had on my old car. They were pretty good !!
Link to comment
They are good. Thats what I have on my sprint car.
Link to comment
The Bremsports or the Compbrake B16 ? Does the Compbrake take the Dynalite pad.
It looks like these are only for a vented disc looking at the disc thickness quoted.
Mine are lightened solids and are only 9.6mm
Oh and what size master cylinders are you running Matt?
Link to comment
I have the Compbrake calipers they come with a spacer in them which you remove to use them on solid discs. I am not sure about the pads I just fitted some Ferodo DS3000 to them not sur eof the part number. I stuck with the stock master cylinder without any problems. With the DS3000 pads they stop very well.
Link to comment
