micky Posted August 5, 2002 Share Posted August 5, 2002 Looking for some advice on how to stop the rear end being so wayward,advice on tyre pressures,spring settings,possible faults that can cause excessive tail slides etc best regards mick Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted August 5, 2002 Share Posted August 5, 2002 It would be easier for you to post what set-up you currently have in order to identify the problem - wrong tyre pressure, to hard a set-up, to high a ride height, spring rates - they all have a knock on effect on each other - don't be embarassed to say you have 28lbs tyre pressure and 500lb springs with a 3 ft ride height using Pirelli 6000 tyres Also what spec of car ? live axle ? independent ? wide ? Enigine ? Quote Link to comment Share on other sites More sharing options...
ACW Posted August 5, 2002 Share Posted August 5, 2002 wotz wrong wiv 6000's anyway..... Of course there could be nothing wrong with the set up it could just be the right foot needs adjusting.. Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted August 5, 2002 Share Posted August 5, 2002 wotz wrong wiv 6000's anyway..... Nuffink ............ with a ton+ of car on top of em + traction control, ABS and power steering Quote Link to comment Share on other sites More sharing options...
