pete g Posted December 22, 2009 Share Posted December 22, 2009 i need a blank for one of my holes on master cylinder any one got aspare or know where i can buy one from. Link to comment Share on other sites More sharing options...
stu999 Posted December 22, 2009 Share Posted December 22, 2009 Would a brake caliper bleed nipple do the job Pete? Link to comment Share on other sites More sharing options...
pete g Posted December 22, 2009 Author Share Posted December 22, 2009 no mate restricted space from clutch master cylinder.i have had to drill below and fit fitting there .need to blank off old hole. Link to comment Share on other sites More sharing options...
stu999 Posted December 22, 2009 Share Posted December 22, 2009 What type fitting do you need, if a bleed nipple won't fit mate? I was picturing an M10 male in my mind, but not sure now - if you say a bleed nipple wont fit You could always cut the 'tube' bit off the nipple, if that helps... Link to comment Share on other sites More sharing options...
pete g Posted December 22, 2009 Author Share Posted December 22, 2009 no because im still using the port.from below. just need a blank bolt only got 8mm to play with clearance. Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted December 23, 2009 Share Posted December 23, 2009 Weld it up Link to comment Share on other sites More sharing options...
pete g Posted December 23, 2009 Author Share Posted December 23, 2009 last resort maybe .easier to fit bolt and cheaper .just need to source one Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted December 23, 2009 Share Posted December 23, 2009 The tapped hole will have a tapered seat which will be crucial to getting a good seal. If you are tapping a new hole, you will need to make sure that it has one as well Link to comment Share on other sites More sharing options...
pete g Posted December 23, 2009 Author Share Posted December 23, 2009 already done 1/8 npt Link to comment Share on other sites More sharing options...
