furtive Posted June 27, 2002 Share Posted June 27, 2002 What's the best way to cut GRP if I don't own a Dremel? I want to enlarge the hole at the front of my nose cone to improve cooling. Doesn't matter if it's not pretty as it's an old nose I will be experimenting on. Quote Link to comment Share on other sites More sharing options...
Blatman Posted June 27, 2002 Share Posted June 27, 2002 Lecky file, lecky sander, hacksaw, manual file. Wear a mask............ Quote Link to comment Share on other sites More sharing options...
furtive Posted June 27, 2002 Author Share Posted June 27, 2002 Thanks. Gimp mask? Quote Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted June 27, 2002 Share Posted June 27, 2002 Use a drill to drill a series of small holes around the inside of where you want to have the hole and then join the holes together with a hacksaw blade. Then use a file and coarse emery paper wrapped around something round, eg bog roll inner, peice of dowel etc to smooth out the shape. John Quote Link to comment Share on other sites More sharing options...
russbif Posted June 27, 2002 Share Posted June 27, 2002 Flapwheel, no contest with anything else, it is controllable and accurate, does the job Russ Quote Link to comment Share on other sites More sharing options...
