Westfield SE 2.0L Fiat Twin Cam
Hi All - its a sad day but onwards to other projects:
Westfield SE
PHOTOS
Narrow body
Mechanically no stone has been left un-turned. Less than 3,500 miles since complete engine re-build. Professionally tuned geometry makes this a superb track car. (tracked 8 times)
I've owned the car for 5 years and she's a lovely example.
2.0 Litre Fiat Twin Cam
First registered 2002
Five speed Abarth gearbox
Heavy duty clutch (2006)
Engine professionally overhauled & totally rebuilt in winter 2006.
Baffled winged sump
Twin Weber 45's (regularly tuned by Tom Airey)
New Weber throttle linkage (June 09)
Custom stainless exhaust manifold & Silencer (98db)
13" Minilite wheels (unmarked)
R888 185x60 Toyo tyres(rears worn)
New 'carbon effect' rear stoneguards (June 09)
AVO coilover shocks (front) & 300lb springs
Protech coilover shocks (rear) & 150lb springs
2008 - professional Geometry & corner weight setup
English live axle (new seals & bearings 2009)
Rear drum brakes (new shoes 2009)
Valvoline racing 20/50w Oil (filter & oil change May09)
Elec. Facet fuel pump
Fuel filter & regulator
Heating & screen de-misters
New black Coverdale tunnel & bulkhead carpets (May 09)
Full tonneau cover (with centre zip)
All over cover, frames & side doors
Halfords car cover
2006 Engine re-build details:
Re-bore & hone to 84.8mm
Skimmed block
New hi-dome pistons and rings
Polished & balance crank
Drill, clean and tap crank oilways
Lightened flywheel & balanced
New propshaft & balanced
New water pump
New 292 deg Colombo & Bariani cams (Euro650 new)
New oil pump and a baffled winged sump (Argenta type)
All new bearings & shells throughout
Tuned Weber 45 DCOES's. (36 chokes)
New stainless 4-2-1 manifold with long primaries
Magnetti Marelli elec dizzy (previously unused) & Marielli coil
Pressure tested head + cleaned valves and seats
New gaskets & seals throughout
New alternator
New starter motor
Stripped & serviced gearbox
New ignition leads
