ciroen c8 - camshaft belt
Got a Citroen C8 family motor - it's a 2.2HdI
was out on Sunday driving along at 50-60mph and the engine just cut out and glided to a halt - no bangs or rattles just cut out
the AA man suspected it was cam belt and the local Citroen dealer now also thinks it is cam belt although they not yet stripped anything down yet to confirm
I had to sit down but they are quoting £1700 to sort it as there are 16 hours or so labour?
I phoned a local independant and they are saying £1500 to sort
am I being ripped off? does anyone want the job locally? is it likely to be the cambelt considering there were no bangs and rattles that you would expect
your thoughts would be appreciated
  • Replies 49
  • Cleggy the Spyder Man
    12
  • sport 2000 Dan
    5
  • stu999
    3
  • Captain Colonial
    3
been reading up on another forum - the valves sit vertical rather than at an angle so maybe no damage to valves and pistons ????
the car is a few years out of warrenty but has only done 53k so it is a bit of a p*****r TBH
the price of £1700 does not incude parts  :bangshead:
Pull the head off yourself and see how bad the damage is?
Might be cheaper just to get a 2nd hand engine and swap over.
Mate of mine had the same happen on his C8 55plate with 55000 miles on it, its very common it went to citroen, he shouted very loud citroen payed for a nice new engine all he had to pay was the initial diagnosis, this was about 5 monthes ago
eeerrr i wouldn't bother trying this job yourself unless you know what you are doing, as the head cannot be removed without the injectors being removed which almost always get stuck in the head, for which there is a 2.5 ton hydraulic puller (special tool) and even this quite often doesn't work!
Does it have full dealer service history? When's the belt due to be changed? If it's within the prescribed timescale and has the correct documented history I'd be tempted to speak to Citroen.
You may not get the answers your looking for, however my experiences working for another Marque are that you may get a contribution towards the cost of repairs. I'd be very doubtful if you will get any assistance without FSH.
Good Luck
£1700 for 16 hours labour  ???
Tell me that's a pisstake  :sheep:
£93.75 per hour  :t-up:
sounds about right for main dealers inc vat these days .... your average marque specialist will be up near 60 plus vat to make money.
On the subject of Manufacturers paying for repairs out of warranty,  BMW replaced my mums 3 series engine at 112,000 miles for the cost of the fluids after I had a go at them.  It had full history, but only independent garages.
I thought new engines were part of a Beemer service schedule :D
I would have said it was £106.25 an hour !!.
your right TGG  :laugh:  - pistonbrokemust have had his beer calculator out last night  ;)  :p
unfortunately the car has a veru patchy service history so wont even bother to kick up a fuss - although I may mention it
dont fancy the hassle of sourcing an engine, then it too being faulty etc etc missus needs to the car back ASAP for scholl runs n stuff
looks like my flexible plastic friend could be taking a hit  :bangshead:  :down:
It put me right off Citroen when I found out (and this is true) they made the steering gear for the Titanic - look how well that worked!
