Fitting a Lotus 2.2 Elite Engine
Hi Folks.... New to the board have a dilemma.
My X-flow engine has died and needs some major stuff doing.. Pistons, con rods , valves, re seat , grind, cam... etc.
So, I can get hold of a Lotus 2.2 16V out of an Elite.. 160BHP, very nice.
However mine is a narrow body. So will it fit, do I need the Lotus gearbox, will that fit ?
Anyone running with one or any ideas wher I might get some answers.
Help... !!     ???
Don't know if it will fit (I have my doubts as from memory the Lotus engine is canted over quite a bit) but why not talk to Paul at Plays Kool Motorsport as they have done a lot of engine changes and might have some info for you - details are on the Links page...
The Lotus engine in the Elite is loosely based on an old Vauxhall lump if I recall.  It's not the Ford based Lotus Twink I don't think.
As peter said it always used to be canted over at a quite severe angle in things like the Jenson Healey and Lotuses - not sure if it *needs* to be like that but it sounds as if it might be quite a tall engine which might present fitting problems.
If it's anything like the "Lotus" twin cam in a Talbot Sunbeam, then it will not fit in a narrow Westfield. You'd have lots if trouble in a wide I would think, too.
It's *everything* like the engine in the Lotus Sunbeam  :D
In that case, I'd have said it was a non starter, especially in a narrow bodied car........
Besides we all know Lotus stands for
Lots
Of
Trouble,
Usually
Serious
don't we......... :0  :0  :D  :D
What Mr ATB needs is a nice Vauxhall engine !!  That'll go in a standard bodied car.  Just.
Naaaaaaaa
N/A Cossie is what he needs :devil:
I KNOW they fit, even in chassis' designed for crossflows :0  :0
Friend of mine has just written off an A3 Turbo - could you get that engine in?!!!! (joke)
Ah, Talbot Sunbeams.....my first car.... :love:  :love:  :love:
:D
Used to do tarmac rallies in a lotus Sunbeam,the first hot hatch. It's a good strong engine bit of a class leader in the late 70’s/80's strong torq curve etc
But it will not fit in a westy of any description as the engine is canted over, this makes it nice and low but very wide. it was based on the old VX lump as found in Firenza/ :arse: Viva with a 16V head bolted on.
Suppose you could fit swept wings to keep  the sump and carbs dry Tee Hee  :p  :p:t-up:
Gezza
having fitted an engine not use but westfield I have found  point why should not !!!!
engine mounts
exhaust system
wiring loom
injection system
ignition system
size of engine
weight of engine (sva)
BIG ONE WILL THE BONNET FIT!!!
gear box
clutch
thrust bearing (will it reach?)
prop shaft
alternator mount
not trying to put you off but this is the list i have had to deal with over the last year
I wish i bought a ztech 2.0l
jamie
good luck
a???
Thanks guys,
Seems I may just buy the engine for use in something else later on down the line........
So, time to rebuild the X-Flow then.
Bore to 1700 ?, What Cam ? , Valves ?, Pistons ?, etc.
Who has the best X-Flow Spec....... ?
